Posts: 63 |
Is it possible to disable this feature? I was wondering because I want to see if the fog light mod will work. I know that I will have to turn them on manually, but that's a price I'm willing to pay.
'99 Silver Contour SE MTX V6 Drop-in K&N / Masked rear Reflector
Posts: 803 |
If I'm not mistaken (and I often am) The fog light mod works with or without DRL. I've done the mod and It worked fine for me.
hunter green 96 mystique mtx, sabb side markers deep tints car bra., K & N filter, hyper white low beams, after market fogs, JVC Kameleon head unit, 600 watt amp with 2 10" kicker subs, soon to come new rims
New adition 01/11/2002 The original 95SE in Midnight Red all the toys including traction control Fog light mod, lightmoonroof switch from a focus, power antena (still wiring it up) post 98 sail panels, new water pump , Bosch quad plaitnum plugs, and a new Cat.
Posts: 63 |
The effect I want is to have my fogs as my DRL's.
Posts: 108 |
To disconnect the DRL 1)Pop hood 2)Take off fuse box cover 3)Pull out the big white relay (the thing is huge you can miss it) 4)Cover fuse box back and close hood
***There you go it's that easy to disconnect the DRL*******
Aaron
98 Mystique GS Silver Frost Pearl V-Racing Aluminum Touring Wing SVT Front Bumper with some added touchs SVT Side Skirts Eibach Sportline Springs 17x7.5 BSA 187 wheels with 215/40ZR/17 Mondeo Badge APC Sidemarkers (Light up Red) Hiper Industries 100W H.I.D. Bulbs (Highs, Lows and Fogs) Blue Reverse Lights Red Turn Signals All Around 2 Red Tenzo R Adjustable Bucket Seats Shaved back door handles (thats right only the back) **And a few other mods** Coming Soon Custom rear bumper, and a sound system
Posts: 287 |
"To disconnect the DRL 1)Pop hood 2)Take off fuse box cover 3)Pull out the big white relay (the thing is huge you can miss it) 4)Cover fuse box back and close hood
Aaron"I was about to say the EXACT same thing! Just check your owners manual to make sure you're pulling the proper fuse. Mike
Posts: 63 |
I thought it was that easy, but I'd thought I'd check anyway. Thanks.
Posts: 92 |
Actually, pulling the DRL in my car kills the driver's side high-beam. I guess they're wired differently after 98...?
1999 SVT Contour - Silver Frost
Posts: 1,040 |
Contrary to what prior posts have stated, pulling DRL alone is not the way to kill the DRL system. US cars without DRLs have a shorting bar installed in relay socket to bypass DRL circuitry.
In any case, poster wants to substitute fogs for reduced voltage headlights to maintain automatic DRL system so some rewiring is necessary.
I have seen posts of this nature and would try a search in the mod section. Sorry, don't have time at the moment to assist by searching or designing detailed circuitry mods. Latter would vary BTW depending on whether you wanted to retain option of having fogs on with headlights or not.
Note that I have said automatic DRL system; to convert to manual would probably be illegal and would definitely be unsafe.
