Posts: 11 |
I get a springing sound when i go over a hump then when i come to the bottom of the hump i get that spring sound not sure which side any suggestions my mechanic says everything is tight. thanks for the help jeff.
k&n drop in filter
Posts: 92 |
Have you had the front spring shields recall done on your car? I had it done, and I got that sound. My friend also had it done, and got the same sound. Kinda like a *spring* *clunk* sound, when your front-end suspension gets compressed, right? (Like when going over a speed bump.) I took it in to Ford for the noise but they couldn't find anything wrong with it. Ditto for my friend.
1999 SVT Contour - Silver Frost
Posts: 1,202 |
Originally posted by LegacySHO: Have you had the front spring shields recall done on your car? I had it done, and I got that sound. My friend also had it done, and got the same sound. Kinda like a *spring* *clunk* sound, when your front-end suspension gets compressed, right? (Like when going over a speed bump.) I took it in to Ford for the noise but they couldn't find anything wrong with it. Ditto for my friend. Hope this recall was on your Mystique and not your SVT because you have aftermarket springs on your SVT and the recall was related to the stock springs.
Posts: 92 |
Right, right...it was on my Mystique. That's what I meant.  By the way, since I bought the SVT I have no idea what recalls have been done on it...can I go to any Ford dealer and just ask? I don't think all dealers share a common database, do they? That would mean I'd have to find the dealer the previous owner used to get that information...
Posts: 11 |
k&n drop in filter
Posts: 11 |
i cant remember if the noise was there before the recall was done but the sound u described is the same 1 i get after a speeed bump the *boing* sound is there. thanks for the reply .
k&n drop in filter
Posts: 36 |
Hey legacy The recalls performed are stored in the Ford Database against the VIN of the CAR. Any Dealer can look up the info
Live your life a quarter mile at a time, for those seconds you are free.
