Posts: 302 |
Where are the drain and fill plugs on the transmission. I was going to change the fluid to Mobil 1 today, and all I can see is one black plug near the botom of the transmission, it has a allen type plug. But I cannot see the one that would be at the top for filling it. Anyone know where it is, what it looks like, what side it's on etc. Remember, it's for a manual, SVT. Thanks for the help.
"It don't mean a thing if you ain't got that swing"!!!
Posts: 61 |
Rydell, There are 2 allen key type drain plugs. One is at the front of the tranny.....where you fill it up, and the second is at the side of the tranny......where you drain it. By side I mean near the oil pan! Hope this helps. Oh yeah, good luck changing it without a syphon hose of some kind to replace the fluid!!!!!!!! Later, Paul
Posts: 302 |
Hey...thanks dude!!! By front of the transmission, do you mean the front of the car? The allen key type plug, is black, right? Do you have to take the plastic shield off the bottom of the car to see, get at the fill plug?? Thanks for the help. Oh yeah.. how's the search for the audi going? Hope you get one, they are sweeeet!!!.
Posts: 92 |
There's a good walk through in the FAQ section, and tells where everything is. Also has anyone actually replaced the fluid with the Ford synthetic fluid, I'm kind of weary of dumping in the coctail.
Has anyone reported any problems with this mod. My car has 90K on it and this is most likely my next job.
E0 Silver Frost, SVT # 4337 Built 12/24/97 !!!
ElKamelion HU, K&N, Momo aluminum Sphere shift knob, no reverse lockout!! Orion Cobalt Amp, 10" Sub
Posts: 1,050 |
I had Dixie Ford do it to my tranny under warranty  While it will not fix your tranny problems per se, it has improve it a bit. The cold shifting was improved somewhat, when its nice and warm outside, it shifts like a hot knife in butter... If I were to spend the money, I would say buy yourself 3 bottles of Mobil1 ATF for 1/3 the price and stick in the friction modifier if you wish. Hope this help. Originally posted by Titan: There's a good walk through in the FAQ section, and tells where everything is. Also has anyone actually replaced the fluid with the Ford synthetic fluid, I'm kind of weary of dumping in the coctail.
alessandro PERFORMANCE FORDS- Unique parts for the contique and cougar SVT Owners Association - Toronto Chapter
SilVer_bulleT@rogers.com 1999 Silver SVT
Funnel Ram, PF Maf Adapter, Magnecore, Brullen Exhaust, Brullen Y-Pipe, O.Z. Supperleggera...MORE toys waiting to be installed... 177hp, 155lb-ft
