Posts: 15 |
How many KM do u change your oil? do u follow the owners manual mine says 8000 KM ? this sounds like 3000 more than i would like to go between changes. i drive about 420 KM/ week . I like castrol GTX oils what do u recomend? I change my own oil any tips ???  thanks for the im fo e-mail me at (contour_982001@yahoo.com) Jeff.
20% lumar tint all around, 80 w mega whites bulbs for the low beam thats all for now!!
Posts: 581 |
I do mine every 5000KM without fail. Since owing the car I have only once gone over the 5000 by less than 100KM.
Posts: 338 |
I change every 5000-6000km. I can if I wish extend it a bit with the synthetic, but I do a lot of city driving so that is my upper limit.
2002 Nissan Sentra SE-R Spec V Vibrant Blue - fully loaded
Posts: 1,421 |
i run synthetic i change the filter at around 3000km then run another2-3000 on the new filter then do a change,i hate castrol,syntec is all i used 2 use until i found out its not real synthetic but they change themolecular structure of regular oil. they take a couple things out and call it synthetic,then charge the same price as real synthetic.use synthetic oil and a good filter
97 gsxr lotsa good stuff 4 sale 95 talon tsi awd turbo loaded sold 95 se 2.5 mtx loaded (fragile handle with care)2 motors 3 trannies custom y with hi flo cat,custom dynomax exhaust,upper cat mod superchip,udp,bat\kkm,proflow maf,ford 9mm wires,svt throttle body,svt intake manifold ,custom kevlar clutch,16 pd. flywheel,svt motor mounts ,svt gauges,eibachs\h&r,omp strut brace,dark chrome 16" rials with 225/50 dunlops,cwazy amounts of audio
Posts: 151 |
I change mine every 5k using Mobil 1 5w30 full synth, best stuff going.
2001 VW Golf GLS 1.8 Turbo 220hp/260tq Porsche Cup 3s rims w/225 45 17 tires Oettinger Grille, Votex Rear Spoiler, and way more mods
Posts: 1,050 |
I agree with all the comments...with synt. you might be able to strecth it out a little longer but if you do city type driving I would change it by 5000km.
Mobil 1 is great... Iahave also tried the Penzoil full syth and it was just as good.
alessandro PERFORMANCE FORDS- Unique parts for the contique and cougar SVT Owners Association - Toronto Chapter
SilVer_bulleT@rogers.com 1999 Silver SVT
Funnel Ram, PF Maf Adapter, Magnecore, Brullen Exhaust, Brullen Y-Pipe, O.Z. Supperleggera...MORE toys waiting to be installed... 177hp, 155lb-ft
Posts: 5,296 |
I think 2-3000 km is overkill. I change mine in 5000 MILES. Originally posted by roland stiller: i run synthetic i change the filter at around 3000km then run another2-3000 on the new filter then do a change,i hate castrol,syntec is all i used 2 use until i found out its not real synthetic but they change themolecular structure of regular oil. they take a couple things out and call it synthetic,then charge the same price as real synthetic.use synthetic oil and a good filter
Posts: 314 |
Every 5000km with non-synthetic Quaker State from Q-Lube. With the amount of K's I put on my car (about 500k/week) I would never be able to afford synthetic. I feel that my engine has never skipped a beat in it's 117000km life.
Black 98' Merc Stique GS MTX Duratec
Cat-back 2.5" SS plumbing with Flowmaster 40 muffler KKM True Rev induction Eibach Lowering Springs 16" Fast 17 wheels with 225/50/16 Potenza RE910's Code alarm with pager 20% tint on sides and 5% on back Alpena Racing pedals Painted calipers (black) 55W & 65W Xenon Headlamps Mobil 1 Synthetic ATF with Ford FM Clear Side Markers w/orange bulbs Removed rear badging
"Park it, or put a porch on it!"
Posts: 1,421 |
ii said i change the filter at 3'000 then run another 2-3,000 on the oil then do an oil and filter change.not jap quaker state filters r made by fram i'd bring a filter into quickie lube
Posts: 15 |
thank u all for the graet replies i will take them into the garage with me when i do my oil change every 5000 Km jeff :p
