Hello fellow contour owners!! :rolleyes: I have a thump noise from the back sus. when i hit a bump . I think its the sway bar rubber bushings any help would b great . Also i need higher output lower driving lights + low beam high beam is ok can any1 tell me where i can buy some in canada i know bat as them in the USA. thanks Jeff confused
20% lumar tint all around, 80 w mega whites bulbs for the low beam thats all for now!!
the noise is probably the sway bar bushing or the end links...get under the car and check the bushings to see if they are cracked...
Do not know about the lighting...
alessandro
PERFORMANCE FORDS- Unique parts for the contique and cougar
SVT Owners Association - Toronto Chapter
SilVer_bulleT@rogers.com
1999 Silver SVT
Funnel Ram, PF Maf Adapter, Magnecore, Brullen Exhaust, Brullen Y-Pipe, O.Z. Supperleggera...MORE toys waiting to be installed...
177hp, 155lb-ft
thanks for the reply but what r the end links?i dont have a shop manual yet
Sometimes a thump in the rear is caused by the emergency brake cables bumping on the trailing arms. Usually the cable housing is tie wrapped to the trailing arms. The tie wrap will break over time and the cables become loose. As the suspension moves up and down, the trailing arms and the brake cables hit.
Just a thought as this what happened to my SE.
BTW, what wattage lights are you looking for? I can get Xenon, Plasma and Hyperwhites from Ractive (Toucan Industries)
Email me privately if you require more information.
2
2
I'm gonna agree with chris on this one, I had the exact same problem, it was just the ebrake cable hitting the rear control arm. Chris is incredibly knowledgeable about our cars, has more info than anyone I know of around here.
Zach
2001 VW Golf GLS 1.8 Turbo
220hp/260tq
Porsche Cup 3s rims w/225 45 17 tires
Oettinger Grille, Votex Rear Spoiler, and way more mods
What's lightning ???
E
E
i think he meant lighting
97 gsxr lotsa good stuff 4 sale
95 talon tsi awd turbo loaded sold
95 se 2.5 mtx loaded (fragile handle with care)2 motors 3 trannies
custom y with hi flo cat,custom dynomax exhaust,upper cat mod
superchip,udp,bat\kkm,proflow maf,ford 9mm wires,svt throttle body,svt intake manifold ,custom kevlar clutch,16 pd. flywheel,svt motor mounts ,svt gauges,eibachs\h&r,omp strut brace,dark chrome 16" rials with 225/50 dunlops,cwazy amounts of audio
Jeff,
The end links are what your sway bar attaches to...I have some pics if you want to see what it might look like.
Anyway, you really need to get under the car to see what is wrong. I know my SVT has a rear thunk when I drive off and it is the e-brake cable. On the other hand, my 96 Contour makes funny noised too and I looked and found it is the bushings with no e-brake problems...I figured the year of you car it might be the same thing.
Try searching the problems forum, this has been discussed in the past, lots of good info.
Happy motoring...
alessandro
1999 Silver SVT
177hp, 155lb-ft
Thank silver for the reply i will look in the archives for more imfo.I just got a shop haynes manual today . Jeff :rolleyes: eek
Moderated by  Gerald_dup1, mbb41_dup1
