#209887 05/08/01 11:11 PM
2
2xtrms Offline OP
2
Well the svt is going on the dyno tonite to see the gains from the MSDS Headers.
830pm at the usual place if anyone is interested.
Zach
2001 VW Golf GLS 1.8 Turbo
220hp/260tq
Porsche Cup 3s rims w/225 45 17 tires
Oettinger Grille, Votex Rear Spoiler, and way more mods
#209888 05/09/01 06:52 PM
So did you end up making it to the dyno? We need numbers...hehe laugh
alessandro
PERFORMANCE FORDS- Unique parts for the contique and cougar
SVT Owners Association - Toronto Chapter
SilVer_bulleT@rogers.com
1999 Silver SVT
Funnel Ram, PF Maf Adapter, Magnecore, Brullen Exhaust, Brullen Y-Pipe, O.Z. Supperleggera...MORE toys waiting to be installed...
177hp, 155lb-ft
#209889 05/09/01 09:41 PM
E
E
where's this usual place
97 gsxr lotsa good stuff 4 sale
95 talon tsi awd turbo loaded sold
95 se 2.5 mtx loaded (fragile handle with care)2 motors 3 trannies
custom y with hi flo cat,custom dynomax exhaust,upper cat mod
superchip,udp,bat\kkm,proflow maf,ford 9mm wires,svt throttle body,svt intake manifold ,custom kevlar clutch,16 pd. flywheel,svt motor mounts ,svt gauges,eibachs\h&r,omp strut brace,dark chrome 16" rials with 225/50 dunlops,cwazy amounts of audio
#209890 05/10/01 03:00 AM
2
2xtrms Offline OP
2
Made it but the numbers are screwed with the new tires. Damn I knew I should have baselined after the new tires.
Zach
220hp/260tq
#209891 05/10/01 03:14 AM
E
E
must b top secret
#209892 05/10/01 01:11 PM
Is your KKM dirty?? laugh
Black 98.5 SVT w/ KKM intake, 73mm MAF, ASP pulley, Optimized stock Y-Pipe, 24mm hollow rear sway bar, Magnaflow resonator, Magnaflow mufflers, Roush springs, KYB struts
#209893 05/10/01 05:27 PM
2
2xtrms Offline OP
2
LOL, no it is clean smile
The one really good thing that came from the dyno was the chip is working as it should again. I'm seeing peak increases of 5hp and 8lbs. It also made the curve way smoother and the rev limiter was moved a little.
The other will be when i change from the the ypipe and cat to the msds setup. We'll finally end the debate over which design is better.
220hp/260tq
#209894 05/11/01 06:50 AM
E
E
2xtrms what r u doin with your cat n y pipe when u get the msds or is this also top secret
#209895 05/11/01 02:46 PM
Zach,
Whats your computer code? It looks like me and you have one of the better and functioning chips with very good performance increases. Also, what octane do you run regularily? Any pinging or other problems?
alessandro
1999 Silver SVT
177hp, 155lb-ft
#209896 05/12/01 04:32 PM
E
E
through further investigation i think i found it
Moderated by  Gerald_dup1, mbb41_dup1
