Jigh octane is deffinatly worth getting if your car is made for it, I think everyone would agree with that. What is to be debated is weather it is worth it ot get the cheaper octane and use the octane boost. Doing this will just end up with frilled up gas. Buy the good stuff and be ahead of the game. If you buy high octane
and the octane boost you may be in for possible engine damage and your engine will probally run poorer. Like it was said before, "...unless you are running high compression or other non-stock equipment there is no reason to get higher octane than they sell at the pump" (loose qoute of course
) If you do have Nitrous or higher compression you may be able to find racing fuel in your area at around 100 octane, but it is expensive. Look around, some Exons sell 93 octane.
Oh well hope this helps,
Mike
