Just curious what the pressure should be for my Kumho Ectsa 712 17" tires
its a V6 98 conotur, i see some places with diff pressures for front / back
i just been running them at 35 PSI all around
To be installed: -New BAT H20 Metal pump (got it) -Bosch Platinum plugs (got them) -9mm fordracing wires (on order) -rear bushings clunk clunk arg! -Intake when $$ is available
Installed: -17" BSA Rims and Kumho 712's -Pioneer Deck and 5x7's -Side markers, ding strips gone
I have the same tires on the factory E0 rims and I run them at 40PSI. I've found that they stick better on a corner than 32-35PSI. I thought about going higher, but I just haven't had time. Just experiment with them a little, but don't go over 50PSI (I think that's MAX).
