#206974 01/08/02 07:34 AM
I put some clear sidemarkers on my car today I didnt want to drive it this winter but the roads aint too bad looks sweeet
Infinity 6 1/2 in. speakers in all doors
2 10in. Kenwood Tornado Subs
Logic Soundlabs 840 watt amp
my car would be sweet if the cops didnt take all my money
#206975 01/08/02 02:36 PM
which ones the A-6? that's what i have and i love em!
CURRENT RIDE: 95 GL
FORMER RIDE: 99 SVT (www.mysvt.com)
"You only live once, but if you lived my life, once would be enough." -Frank Sinatra
#206976 01/08/02 09:30 PM
E
E
Those always look sweet. My dad wont let me put them on because he is afraid of rusting. So I might have to go with LED's in the mirror housings.
Does anyone know where I can find a strip of LED lights around here? I've checked RadioShack and Checkers with no luck.
It's not always about looks, but what helps drivers the most, some of them need as much help as they can get.
'95 Contour GL, zetec mtx, drop in K&N, exhaust res removed, 4 10" Kenwoods powered by 1000W Visonik amp, 4 5"x7"/6"x8" Visoniks
"Buy American or apply for Japanese welfare."
www.geocities.com/fordcontour05/contour.html
#206977 01/08/02 11:08 PM
get side markers dude just wherever you drill put rust-stop on it . I went to pep boys and got APCs but put red bulbs in there instead.plus my headlights arent clear so I didnt want really clear ones
#206978 01/10/02 02:16 AM
Where do you wire those? That's the main thing holding me back from doing that to my contour. That and worrying about rusting, rust-stop or not. Its salty here in MN.
Can anyone believe the weather we're having this week? I installed new speakers outdoors today in nothing but jeans and a sweatshirt! my kind of January!
-APD
nothing serious about my car
'96 Contour GL
Zetec, 5 speed
my cute little system:
1 Pioneer DEH-2300 (50X4)
4 6X8 Pioneer 3-ways
2 JL audio 12" subs
1 Kenwood amp (given used, not sure about wattage)
#206979 01/10/02 03:36 AM
I just peeled off the bages ,drilled a 1 in. hole where the badge used to be, dremmeled the edeges,and took out the corners and spliced into the ground and fatter blue wires. I am not worried about rust cause mines parked during the winters but as long as you wash it the engine should heat off most of the water pretty quick.but if you for sure wanted it permanent you could bead caulking(clear silicone) around the hole and then put the sidemarker on. and the weather kicks arse I work outside so Im pumped
