lol, no worries Karl, I just thought it a bit easy for others to dismiss it as "simply a blower and a six speed" and not realizing the other significant changes to accomodate the blower, etc.
Engine
Carryover Crankshaft (very stout forged unit already)
New Heads - ports redesigned for improved flow throughout the rev range
New Cams - designed to optimize the tq curve (ie that flat as Kansas look on the dyno plots)
Iron Block - to improve longterm durability of the block under heavy torque loads
Con. Rods - Really cool forged steel H-beam supplied by Manley.
Pistons - Forged aluminum, designed for boost, and 8.5:1 compression
Supercharger - Eaton M112, same basic blower as lightning, but the case was redesigned to meet the design requirements for the Cobra. Outputs ~8psi
Fuel - larger fuel injectors, and a larger fuel pump to feed the beast.
Intercooler - water to air unit nestled in the valley below the supercharger. W/ the accompanying radiator low in the front of the car.
Flywheel - lightweight aluminum unit.
Driveline
Trans - Tremec T56 w/ Cobra specific ratios
Driveshaft - Lightweight aluminum unit
Rear Axle - new 3.55 ratio gears spinning beefed up axle shafts
Plus the goodies on the inside and on the body
Not to mention the suspension re-tuning
