Posts: 3,237 |
No. This has been asked a few times before. The Falcon is a TOTALLY different car. It is larger, RWD, has a longitudely mounted engine (4.0L I-6 or 5.4L V8) and is of course on a totally different platform unique to the Australian market.
Posts: 1,196 |
Would that car, in terms of size, be more comparable to the Focus, Contour, or Taurus? At any rate, this style is what the newest Focus or Taurus designs should have been! I can't wait to see it in the US!
Matthew 98.5 Contour SE V6 It has spent 1.5 years under the wrong identity ;-)
Posts: 79 |
I don't think it is the equivalent of the focus or taurus, it's somewhat in a category of it's own. In my opinion it's closest match to a similar North American Ford car would probably be the Mustang - Judging by the tech spec's that is. With the exception that it probably handles better, and looks completely different.
Posts: 1,493 |
Size wise it is like the Taurus, but it is like a Mustang underneath.
Up until the mid 70's the AUS Falcon was the same as the 60's US Falcon/Maverick platform, (Mad Max's car). Then in '79, instead of using the US Fox Fairmont, they borrowed Euro RWD platforms. Now it is a unique AUS platform.
2000 SE fleet, V6, ATX, ABS, no spoiler, T-Green/tan. Built 01/2000 in MO. Added 12 spoke factory SE rims, K&N. Biggest mod: ESP Plan!
Posts: 1,445 |
fairmont?? futura??? holy crap when's the grenada coming back the new pinto will be a civic beater i hope
95 contour se...dark blue...monsterflow air filter...remanuf atx...wiring harness recall or bust!!!96k miles...motorcraft awsf32pp plugs & red ford racing 9mm wires...kvr black plated cross-drilled rotors & carbon fiber pads...currently undergoing renovation...excuse our dust!!! are my dodgers for real????
Posts: 1,861 |
Could this be a GTO competitor? 5.4 V8 and rear wheel drive makes it sould like it may have what it needs to square off against the GM up and coming hot car.
Jim Johnson 98 SVT
Administrator
Administrator
Posts: 5,037 |
Pssssst!
[WHISPER]"Ford 500...."[/WHISPER]
Posts: 1,087 |
Looks like a Volvo to me...
Posts: 1,493 |
"5.4 V8 and rear wheel drive makes it sould like it may have what it needs to square off against the GM up and coming hot car." It will square off with GM, but only Down Under, against the GM Holden "Catera GTO". US won;t get it, unless the 2004 GTO takes off.
