Hey i just got xenon lights from midnightmoose.com (9006 for low beams) So I walk outside to install it (98 svt) and i dont have any idea what to do. Do I need any tools or anything ? Can anyone tell me how to replace my stock low beam bulbs with my 9006 xenons ? Thanks a lot.
98 svt
I'm assuming these are just xenon replacement bulbs, and not an HID kit. Things are very tight behind the Contour's headlight assemblies, so you will need to remove them in order to replace the bulbs. To remove them, remove the two securing screws at the top of each assembly. Pop the assembly out, remove the wiring harness, remove the old bulb with a twist. Install the xenon bulbs and reverse the process; you're done.
Its actually 3 Torx screws on my car, 2 on top, one on the bottom behind the assembly (just needs to be loosened up) you should see them...simple job cool
[[Justin]]
'98 Silver Frost SVT
#2089/6535
I am made of cheese
My car is in the shop
When I drop the clutch, I get wheel hop
Do not eat me, oh please
Right you are...sorry about that.
thanks guys im gonna try it today
98 svt
