Posts: 2,794 |
I need wheel spacers..about 2-3mm....Wilwoods will hit Konig Imagines in 17" size...I know i can get them sent to me but is there anyplace local I can buy them?
Just call me Judge. People suck. Life begins at 170mph...until that point it is just boring.....
Posts: 6 |
if you live near the livonia area go to a place called first class auto on plymoth rd. and wayne rd. they're open mon.-fri. 9 a.m.-5p.m. best place to go for anything. www.firstclassauto.com
Posts: 372 |
never ever ever EVER go to first class for ANYTHING... talk to people who know what there doing...not those clowns.
Black SVT No Mods, slow as piss
"Real men drive sticks, get chicks that love dikzz"
Posts: 2,708 |
Judge, you might want to grind the edge of the wilwood calipers (Same as Antonio did w/ the Baer's) that hit the wheels instead of spacing the wheels. wheels spacers could very well lead to bad wheel bearings... -Mark
You can do something for Love... You can do something for Money... But there is nothing quite so satisfying as doing something out of Spite. GTExtreme1@aol.com
Posts: 93 |
I got the same problem with my 18" axis sevens. I got the wilwood kit and in needs 3 or 4 mm to clear. I found a 5mm spacer from H&R it comes with longer studs too, but I don't know where to get the studs install since I do not have the tools for that kind of job. JUDGE let me know what you come out with.
about grinding the caliper I do not want to put at risk the integrity of the caliper.
I order the 17" FSVT wheels from bat for winter and they clear fine. Erick from BAT test fit them for me. They were $540 for all 4
"You can turn a engineer into a sale man but, you can not turn a sale man into an engineer" "I have walk to the valley of Honda and death for that I should not fear no V-tech"
99 cougar,SVT manifold convertion, Tranny upgrade by Haines Motor sports (Quaife lds, Fidanza flywheel, and Clutch Master Stage 3 clutch) 18" Axis Se7ends,GC coiovers,sho sho Y pipe,Wilwood4 piston brake kit
Posts: 2,794 |
I ma doing the repair myself...and am just doing spacers for now. I am not messing with anything else....
Posts: 93 |
yes but you gotta change the stud if not you stock one will brake and yo may sufer some kind of vivration at high speed let me know I think the sapcer are like $75 from tirerack
Posts: 156 |
I got my H&R spacers from S&G. If you don't install the longer stud the factor stud will break. I know, was in Chicago on a Saturday Had my install done and DJT Motorsports 313-895-9353
Posts: 2,794 |
Well, I have no choice but to fight the install in my driveway because the car is not drivable as is. Hopefully the studs do not fight me to much....as my wheelbearings are new and do not want to mess them up.
Posts: 93 |
Here is the info I got from Terry
"For such thin spacers the std studs should be ok.The 'rule ' is that the lug nut must have 2 1/2 times the diameter of the stud for engagement in the lug nut to be safe..TH"
