Posts: 165 |
Just be sure not to lock the car!!! :rolleyes:
'96 Mystique, Zetec, MTX. ---Mods--- Removed both intake resonators and airbox. Installed APC air filter and APC crankcase ventilation filter. Removed exhaust resonator. Installed XM Satellite Radio. Replaced bad alternator and 175a fusible link...much fun! Intake plenum---GONE!!!! My car growls louder than yours. If I can't buy it, I'll build it...Trust Me!!!!
Posts: 182 |
Only way I can get mine to turn off is put the keys in the ignition and turn the key...pressing it again dosent do anything. I just wish it did like my friends Camaro does...lock your car with the remote, and unlock it manually (i.e. left the windows down, theif sticks armn thru window and slides lock manually) and open the door....BEEP BEEP BEEP BEEP! I wonder if there's a way I can do that...
YOUNGEST CEG MEMBER  1995 Mystique LS V6 ATX, Moonlight Blue Clearcoat Metallic, Atlantis blue cloth. Fully loaded except leather, sunroof, and CD. 1990 Pontiac 6000 S/E AWD Brilliant White with 2-tone Gray leather, fully loaded
Posts: 3,419 |
Originally posted by sosaudio: Just be sure not to lock the car!!! :rolleyes: Thought of that - window gets rolled down.
Posts: 1,428 |
Originally posted by javaContour: ...Or for the really ambitious, remote starter. Of course PATS would need bypassed in many cars, but it probably could be done...
Rather try this maybe ... 250$ later you have a fully configurable alarm system with shock sensor, dual horns, remote start, PATS disable, extended range remotes, etc.. Keep the OEM keyless for when you give the car to a valet or the dealership. ..that's what I did..
Posts: 1,196 |
Originally posted by Moonlight Mystique: Only way I can get mine to turn off is put the keys in the ignition and turn the key...pressing it again dosent do anything. I just wish it did like my friends Camaro does...lock your car with the remote, and unlock it manually (i.e. left the windows down, theif sticks armn thru window and slides lock manually) and open the door....BEEP BEEP BEEP BEEP! I wonder if there's a way I can do that... Um, he has a security system. You just have keyless entry with a silly Panic feature  :p (eh, I'll just add that I thought about this too... but you'd need to buy a real security system with shock sensors and lock detectors before it will work)
Matthew 98.5 Contour SE V6 It has spent 1.5 years under the wrong identity ;-)
Posts: 452 |
Originally posted by gwellington: Without the Panic button, how do you find your car in the Wal-Mart parking lot? First of all, what are you doing at Wal-Mart? Second, like someone else said, at especially Wal-Mart, you have to park way away from everyone else to avoid dings.
Silver E1 I'm afraid Speed Demon has given me the mod bug. AIM: Davo7Wins
Posts: 142 |
i dont have to worry about my panic alarm cuz my keyless entry only works at a 10 foot distance lol. it even has new batteries in it.
-1988 Bronco II: Blue and silver with 8 shades of rust. The system costs more than the vehicle  -1999 SVT Contour: Silver Frost, tinted windows, stock for now... -------- "Never slap a man that's chewin tobacco"
Posts: 1,244 |
Originally posted by Joey: Originally posted by gwellington: [b]Without the Panic button, how do you find your car in the Wal-Mart parking lot? Mine's the one way down at the end of the lot, where no other cars dare to park...
I hate door dings![/b]Yep and then you get the guy that thinks hit sh*tt*r has to be right next to you!!!!!
Posts: 116 |
Mine's the one way down at the end of the lot, where no other cars dare to park... Yeah, it's the one way back there in that dark corner of the parking lot, getting the radio jacked out of it, because it's right back there where nobody even looks even if your annoying alarm is going off anyways (people just think that the owner accidently hit his panic button and is just fumbling to find his remote)
'95 CONTOUR SE -Enkei 16s -Porsche944 Exhaust tip - Audi xenon projector headlights -Peterbilt 30" air horns -mp3 Aiwa headunit (150 songs on one disc) -dual 10s -soon to have LED tailights (real kind, not just gay bulbs) -That's it for now
