Originally posted by Roger R:
[b]Heres what you do, go to the quarter car wash and use the engine degreaser and wash the whole engine/compartment down REAL good and rinse. Then drive it for a while to dry it off and use a towel to get the rest of the water off. Next spray your choice of foaming tire shine (the cheap stuff works fine) on EVERYTHING and shut the hood. Your going to have to wash your car because the product, when sprayed out of the aerosol can, will get everywhere, even if you do it in the garage. By the time your done washing your car pop the hood and admire the results
If your engine compartment/engine are REAL bad repeat the 1st step 2 to 3 more times. Also the stuff that works the best for a "show shine" is Black Magic tire wet in the aerosol can but it does accumilate the dust after a while but thats ok, just go back to car wash when you don't like it and wash the engine compartment down again and you should still have some of it that "soaked" into stuff
Good luck!
