#183528 01/12/02 06:29 PM
anyone ever have this problem? when i go to turn it over once in a while, nothign happens. all the lights on the dash come on, but nothing turns over, ther's no noise or anything. it takes 4 or 5 times before it will start.. is my starter going out?? anyone have any other suggestions??
thanks,
mike
'00 T-Red SVT
KKM, Borla, 35% Tint.
18" Arelli Czar wrapped in 225/40 Toyo Proxes FZ4's.
2 12" Polk Audio Subs, 800 watt Power Acoustic Amp, Alpine in-dash.
#183529 01/12/02 08:53 PM
with those 4 or 5 starts.......is your starter actually trying to turn over???
-Mancho- cars name is Connie
99 Silver Frost SVT #1986
k&n filter with cut out box
true duals w/ flows smile
Ground Controls with 17's mille miglia ...
Hightower headlights
15.4 at 90.29 at Milan dragway before the true duals smile
#183530 01/12/02 11:07 PM
Either the starter, or your ignition switch is having difficulty finding 'start'-hitting 'on' instead, or your Neutral/Drive switch is going bad (assuming you have a non-european MTX75)-indicating that you are in drive when you try to start.
I'd check the NDS switch first--it is the cheapest to replace. If you have a scan tool, read the 'NDSFLG' or 'PNP' parameter (PID 1101, 1 byte, bit 1, 0=neutral). If you don't have a scan tool, try mashing the clutch pedal between attempts and see if that effects the number of attempts before the starter kicks in--not a conclusive test by any means.
1999 Contour SE Sport MTX75 T-Red/Grey
Audio: Pioneer DEH-7400MP (MP3 CD), Pioneer TS-A6857 front & rear, PPI PCX-250, Infinity Perfect 10.1
Other: cup holders, cargo net, Blizzaks, Potenza RE950s
#183531 01/14/02 01:09 AM
with those 4 or 5 starts, nothing happens, at least not for turnign over wise. all the dash lights come on, but no noise or turn over or anythign with the ignition. it doesn't always happen though, today, the car started fine. no problems at any start up today...
'00 T-Red SVT
#183532 01/15/02 01:23 AM
Check the connection's.....and maybe the starter soleniod is going........I would have it checked out though.....Most auto parts stores check them for free if you can take off your starter....if not i believe that its 16 bucks at Pep Boys....I hope I helped you out......If i was you i would check the connection's first smile
#183533 01/15/02 01:27 AM
thanks i appreciate it greatly....
'00 T-Red SVT
#183534 01/15/02 01:29 AM
no problem laugh ....How many miles??
Moderated by  WorldTour_dup1
