Stephen Offline OP
Has this been thought of before?
For a cold air intake, making the air conditioning cool the air before it enters the engine!
Just a thought, tis' all!
Stephen
96 Contour, GL, Zetec, ATX.
03/18/1996 Build Date.
Drop in K&N
NGK Laser Platinum Premium Spark plugs
Niehoff Premium Ignition wires
Wheel Well Air Intake Resonator removed.
*Just the beginning*
Isn't that what an intercooler does ??
I'd imagine using the AC would kill your mileage too...
'98 Mystique LS V6 MTX
"Unprofessional driver, wide open course."
#9 - Hitting .400 for ever
"Wake up the damn Bambino; I'll drill him in the ass." -- Pedro Martinez
"The MTX75 was not designed to be a drag racing transmission" -- Terry Haines
Stephen Offline OP
True, it will take away from your mileage, but the thought was to have it there when you want it and not on all the time!
Could it be done and cost less $$$ than the intercooler?
It is just an idea! :p
Stephen
Drop in K&N
A/C takes a lot of power out of the motor too. Sorta seems like defeating it's own purpose. Cool thought though. wink
1998 Contour Sport V6, Black
*Cold air induction
*Powdercoated intake manifold (more powdercoating coming soon)
*Blue headlights, foggies, and signals (no reflectors)
*CEG stickers & removed door moldings
1994 Ford Aspire 4-door, looks like a big egg
*64 hp 4-cyl
*5 speed
*"13 steel rims with go-cart tires
*74 mph top speed
*I'm going to auto-x the thing (but not compete)
[QB]Isn't that what an intercooler does ??[QB]
Intercooler lowers the temperature of an air charge by cooling it with outside air.
no, this idea wouldn't work because of the second law of thermodynamics. it's the same principle which makes perpetual machines impossible.
basically, rather converting engine power to heat removal then back, you'd be better off not running the A/C at all.
-Louis
1998 Black E0 #3826, lightly modded
O
O
I never really thought of putting an intercooler on a car without F/I...would it even be worth it?
IMO, not really. for the time and trouble of plumbing an intercooler, it'd be easier and more effective to just relocating the filter.
-Louis
http://www.contour.org/forums/ultimatebb.php?ubb=get_topic;f=6;t=004903
After having thought about it more, it's too much trouble for the little gain you'd get.
Eric B.
Ottawa, ON, Canada
98 Mystique V6 5spd. Toreador Red
Modified Airbox with K&N drop-in, Cool Blue bulbs, Homemade solid brass shifter knob, Sony CDX-L300 head unit
http://photos.yahoo.com/LBuzzer/
