i don't really consider this a problem,but was just wondering if anyone else's 'tour idles higher with the a/c on?my normal idle is 750 but it jumps to about 900 with the air on...also the throttle hang is alot worse ,hangs at about 2800 to 3000 before dropping for longer than usual..i do have the normal throttle hang,just worse with a/c on..just curious if i was the only one,all my other cars idle a little lower with the a/c on..
98 silver frost svt
no cats/magnaflows
kkm true-rev
white hvac
ford blue calipers
more to come!!
yes it needs to keep the idle up to run the a/c compressor if im not mistaken.
throttle hang is worse cause there is more drag on the engine (getting UDP reduces throttle hang but screws your engine up)
hth
95 SE Champagne Mettalic
True Dual exhaust with X pipe and Redline mufflers
KKM Tru Rev intake
H&R Springs/KYB struts
Apex-i S-AFC
65mm Throttle Body
17" Ace Spades
4 Pt Racing Harness
Window Tint all around
New Engine @ 117k kilometers
G-Tech: 15.6 @ 91.5 MPH
"you officially kick ass"
quote from awed CEG'er after i chopped my hood and threw on scoops
RIP 98 SVT silverfrost *nov 4 2001*
i do, mine idles at a lil over a grand when the ac is on. it's normally at 800
2000 Contour SE ATX Zetec
Mods- smile
AIM: CZboyovski
SVT exhaust
Z\'s Contour
Having the A/C on takes so much extra power. You're basically in a Corsica with that A/C on.
Silver E1
I'm afraid Speed Demon has given me the mod bug.
AIM: Davo7Wins
no doubt it feels like i am losing about 50 horsepower with it on..takes away all my power...its just that it seems most cars bog down w/ the a/c on,and most of my previous cars idled lower than stock w/it on..
98 silver frost svt
no cats/magnaflows
kkm true-rev
white hvac
ford blue calipers
more to come!!
9
9
Every car I've ever been in has idled a little higher with the AC on...
1999 CONTOUR SE SPORT
2001 HONDA CIVIC LX SEDAN
- 1.7L 5 Spd
- '02 SI RIMS
- Reverse Indiglo Gauges
"Biblical principles work, there are no exceptions."
www.geocities.com/jesusfr7282000
http://www.7thgencivic.com/members_rides/member.cfm?id=5895
9
9
Yep, and I try not using the a/c in city driving as the idle is totally wacked. If I'm going to use it I flip in on just before I get on the freeway when the engine is always at least near its power band. By the way, 195 - 200 hp (SVT) or not, 2.5 liters is still a small engine and I wouldn't expect it to handle all the luxury accessories it is expect to with much aplomb.
Karl
*** It's all about consistency! ***
98 SVT Contour
86 Ranger GT
69 Fiat 850 Sport Spider
67 Formula-S Barracuda
Just curious. Has anyone tried to dyno their car with and with out the AC on? Im just curious to how much HP it really takes.
~~~~~~Mike~~~~~~
Silver 2000 Contour SVT
# 1200 of 2150
I was thinking the same thing.
2000 Contour Zetec ATX
Hector
Mods...I got em'
"Contour grills, Contour bills, check out the oil my Contour spills."
2.SLO = 17.6 at 80mph
My profile
It probably loses 10-15hp w/ the A/C on. It switches off at WOT so that's where I drive. laugh I don't use the A/C unless I absolutely have to.
"If you're pushing crazy I'm all full up here."
{Black '96 Contour SE MTX w/ over 126k on the clock}
· Get the skinny here.
· Need a 96-00 Ford Service Manual on CDROM?
