Originally posted by SVTJOE1:
Donny, Thats ok..I understand. Well, I got some time consuming stuff done. I got all the doors apart... I got the componets up and running along with the rear 5x7's. It took me about 5hours to do....But it sounds great and its still running through the factory amp! So....What I will have to get done is...I need a power wire ran back to the amps from the battery.....I need the RCA hooked up and the factory amp bypassed...Then I need the oter amp (sub amp) hooked up to the distribution block... That should be it...I hope I knocked the cost down of the labor by doing that other stuff myself?? I have friday evening off..I get off at 4:00... Let me know.. I work all day on saterday.
Thanks man,
Joe
WOW! I told you what needed to get done, and you did it!! GREAT JOB! I told you could do most of it yourself...
Proud of you man, once you do it about one or two more times, you'll be flying at installing door speakers.
Not as hard as you thought huh?
Damn, still surprised you did what I told you...
