#177110 09/02/01 03:30 AM
Hey Gang,
So got this egg damage to the clear coat. Pretty much my cuz and I got some bug and tar removing car soap and attacked it with some 100% diaper rags... (Yes clean smile Got it all off we thought but once it dried you can tell the clear coat is damaged or has residue on it still.
So any Ideas besides a recommeded detail shop are welcome.
TIA,
Ray
I would use a clay bar and try it yourself, can I suggest Mequiers clay bar, simply the best. I detail cars on the side incase you need your car "protected" before the winter. Like Bon-Bilt..."I do good work!"
Roger R
SVT/SHO Society SE MI rep
2000 CSVT #1253 of 2150
silver frost/midnight blue
2-8" dark blue racing stripes
Mequiars...simply the best!
"...and number 5, now this is the most important Rat, when it comes to making out, whenever possible, put on side one of Led Zeppelin 4"
USMondeo@aol.com
8
8
Clay bar will remove residue but not damage to the clearcoat. Let me guess the spot looks like fine nicks in the surface in a circle right?. Get the spot wet if it goes away then it is in the clearcoat and has not gotten down to the basecolor. Use some ultra fine paper like 2000 grit and some polish by machine or hand and you should be able to remove the spot. Watch that you don't go to far I don't think Ford puts a whole lot of clear on their vehicles as compared to GM witch I'm used to dealing with.
Matt
01 S-10 crewcab
83 Mustang GT some mods.
Matt
01 S-10 crewcab
Actually it looks like a water stain to me.. but it does disapear if you put water on it.
Got to get me a clay bar..
Ray
Moderated by  WorldTour_dup1
