#22876 07/05/02 10:28 AM
gdub520 Offline OP
sorta anyway....i bought a mothers cali gold (?) claybar kit which includes showtime detailer a claybar and a small bottle of wax for 16 bucks....bought it a couple weeks ago and lost the directions so i had to do it by memory (first time ever trying)
a month ago someone decided to give my hood a cool wrigleys mod....well i finally got it all removed weds after a good soapy wash with some dish soap and a fingernail (got great suggestion on how to remove but its so hot here now that the sun just baked the **** outta the gum and i rubbed a little more of it off everyday with my finger)
sprayed on some showtime and got to work....the dirt this thing pulled up was unbelievable eek ...had no idea a car could still be so dirty after a good washing and the difference in the sound and feel of the claybarred hood and the fender i didn't touch was like nite and day...fender felt and sounded rough hood smooth as glass...u can actually feel the finish smooth out as u run the clay back and forth
i didnt' wax as it was getting dark so thurs i rinsed the car off again and redid the hood and waxed it....looks pretty good if i do say so myself...then i did the roof and trunk and waxed them both but the sides will have to wait til another day
there is not a trace of the gum now thankfully and my car looks much better than it did although i didnt do a perfect job of it....i ran outta rags to finish the job and someone was threatening to eat my share of the bbq....some things are more important than the tour if thats possible laugh
overall very happy with the product and had to answer a ton of questions while i was working in front in the driveway for folks asking what the heck i was doing
no zaino wars please laugh
95 contour se...dark blue...monsterflow air filter...remanuf atx...wiring harness recall or bust!!!96k miles...motorcraft awsf32pp plugs & red ford racing 9mm wires...kvr black plated cross-drilled rotors & carbon fiber pads...currently undergoing renovation...excuse our dust!!!
are my dodgers for real????
#22877 07/05/02 10:41 AM
9
9
Uh, if you claybarred your car, you might want to wax it really soon as the clay removes the old wax also which opens your paint to the harmful rays of the sun. You might want to check on this. You do not want your paint exposed like this for too long, if at all...
1999 CONTOUR SE SPORT
2001 HONDA CIVIC LX SEDAN
- 1.7L 5 Spd
- '02 SI RIMS
- Reverse Indiglo Gauges
"Biblical principles work, there are no exceptions."
www.geocities.com/jesusfr7282000
http://www.7thgencivic.com/members_rides/member.cfm?id=5895
#22878 07/05/02 12:22 PM
Clay bar question: will that stuff remove the "spider-web" swirl marks that seem to come to every car over time? My Mystique's paint is really bad for that right now and buffing means the clearcoat gets a little thinner and I want to avoid that if at all possible...
Thanks for your opinions!
Eric B.
Ottawa, ON, Canada
98 Mystique V6 5spd. Toreador Red
Modified Airbox with K&N drop-in, Cool Blue bulbs, Homemade solid brass shifter knob, Sony CDX-L300 head unit
http://photos.yahoo.com/LBuzzer/
#22879 07/05/02 12:51 PM
APT Offline
Actually, Dawn removed the old wax, but gdub, you need to get some wax on there.
LBuzzer, Clay bar removes contaminants in in the paint. It doesn't nothing fo swirl marks. You can try a high quality wax to cover it up, but a rubbing compund is the ony way to remove them and a buffer makes it quicker. I have tried a buffer once, butam not very good. So, I use rubbing compound by hand which takes longer. I recommend 3M Perfect It II #39005.
#22880 07/05/02 12:55 PM
I barred my SVT, SE, SE and Grand Am. That $#)t really works! I do agree about waxing. It rained shortly after I did my car and it didn't seem to bead very well.
As far as the swirl marks, it won't work too good. I bought the Meguirs step 1 paint cleaner. (I couldn't find the Mother's equivalent). It is a very mild compound cleaner and it did take the fingernail marks under the door handles. That made a big difference.
I received a free bottle of Meguirs spray carnauba wax the other day and I tried it last night. It is a much thicker spray than some spray waxes I've used. I am VERY impressed with it. The finish is very smooth.
Get to waxing gdub
98 SE Duratec/MTX Plain Jane (for now)
98SVT #231/6535 Stock
www.pbase.com/ddehoyos/svt
#22881 07/05/02 01:01 PM
Oh btw, I don't recommend using the same bar for too many uses. I t does wear out. I almost didn't work anymore by the time I got to the Grand Am.
I wanted to buy another bar by itslef but it isn't sold alone. I could buy a bar that is twice the size for 4 bucks more at my parts store. It is the type that bodyshops and detailers use. It uses water as the lubricant instead of the showtime stuff. I really haven't decided if I'll buy that or another Mother's kit.
Any suggestions?
#22882 07/05/02 02:26 PM
Go with the bar alone. It will probably last longer and you won't be stuck with two Mother's products you won't use.
Silver E1
I'm afraid Speed Demon has given me the mod bug.
AIM: Davo7Wins
#22883 07/06/02 09:45 AM
gdub520 Offline OP
sorry i guess i didn't type some things so clearly....i started on the car on wed with the wash and claybarring the hood...then darkness fell upon the land
so thurs i rinsed the car and dried it off and did the hood just a little more on the drivers side where it was still a little rough followed by a wax...then i barred the roof and waxed and then the trunk plus wax
overall i like the product and i think the showtime spray gives the bar a smooth surface to glide which i guess is to help minimize damage to the paint and maybe to keep the bar from sticking...without the spray u're gonna create friction that will melt the claybar i would think
and i definitely will not be using this car again after i do the sides
the wax im not so crazy about though...very very thin and at one point when i wasn't paying attention i bent over slightly and spilled a ****load on my fender and the ground
i'll find another wax to use next time use a claybar
does anyone know if theres' a recommendation on how often your finish would need something like this???
#22884 07/06/02 11:12 AM
Anything I can do to cover chips on my front bumper other than repainting it...you know since we're on the subject. smile
2000 Contour Zetec ATX
Hector
Mods...I got em'
"Contour grills, Contour bills, check out the oil my Contour spills."
2.SLO = 17.6 at 80mph
My profile
#22885 07/06/02 02:39 PM
www.paintscratch.com Order some touchup paint and follow the directions. laugh It took me nearly 6 hours to touchup my hood alone, looks much better though.
~~~~~~Mike~~~~~~
Silver 2000 Contour SVT
# 1200 of 2150
