Posts: 45 |
I was wondering when/how one grduates from a "New CEG'er" to a fully fledged, "CEG'er"? I also wonder what the "Rate Member" link does. Perhaps if I knew the answer to the latter, I would realise the former!! Looking forward to your input.
David BC
White '96 Mystique GS ATX - A work in progress! White '88 Cherokee - still going places!
Posts: 303 |
I think you need either 30 or 40 posts, that's all. I was a "New CEG'er" for way too long.
BTW, where in BC are you?
Kerry
99 SVT Contour Silver Frost, #365/2760 91 Isuzu Impulse XS Kammback, Handling By Lotus Victoria, BC, Canada
Posts: 45 |
David BC
Posts: 1,196 |
30 posts if I'm not mistaken.
BTW, the "Rate Member" feature allows other members to rate you on a scale of 1 to 5 (5 being best and 1 being worst). You can turn this feature off if you want. This also allows, for the most part, other members to determine the validity of your posts or exactly how well-liked you are on the forum.
Matthew 98.5 Contour SE V6 It has spent 1.5 years under the wrong identity ;-)
Posts: 544 |
Send me 20 bucks and then post 30 times, I'll get rid of it.
Administrator
Administrator
Posts: 275 |
On your 31st post you will no longer be a "New CEG'er". You can rate other members from 1 to 5 stars by using the rate member link...they can also rate you, which is what you see under your name and member number. You have the ability to turn that option off if you want via your personal profile selections.
=) Christy
01 Outback Limited Wagon with all the goodies I also get to drive my hubby's 95 SE!!!
Posts: 45 |
Thanks to all who replied, I appreciate the answers. Now, to write some posts!
David BC
Posts: 45 |
David BC
Posts: 159 |
This also allows, for the most part, other members to determine the validity of your posts or exactly how well-liked you are on the forum. So what makes one "well liked"?
Posts: 1,391 |
Joe, 98 GL sport (V6 MTX)
