Posts: 20 |
How many of you have installed the dual mode dampener on your SVT? What band did you use? What are your reasons why you installed the dual mode dampener? If you do not have one installed, are there any reasons why?
Thanks
Posts: 2,277 |
do it cuz Terry told you to do it, nuff said. hehe j/k
Kim 2001 Mercury Cougar C2 1995 Contour GL Quote: Originally posted by shotwell: Yeah, I keep checking too. I'm afraid that just as the site goes down my car will burst into flames or something (knocking rapidly on wood)!
Posts: 49 |
Originally posted by Wiser: If you do not have one installed, are there any reasons why?
Thanks Because I'm waiting for the one I ordered to arrive at Elky's house.
Everyone is willing to help me in past tense.
Posts: 1,444 |
Posts: 3,419 |
"What band did you use?" Care to explain that one better?
The Dual Mode Damper lessens the tendancy of the crank to "bounce" around in its bearings, which isn't good for bearing life. The difference you will notice is a much smoother feel in the higher revs.
Posts: 345 |
Red '98 SVT E0 3098/6535 KKM, Elizabethan EGR Plate, TH fix OMP front brace Hightower rear brace DMD B&M with reverse lockout disabled and centering spring removed Mobil 1 oil and trans fluid A6 Side Markers, Optima orange, Horn recontent Painted Sail Panels VooDoo Knob and pedals, RogerR deadpedal Blau Houston & CD changer Cup holders that work Donnelly mirror BAT Sill Plates and a Bullitt fuel door
Posts: 20 |
I guess a dual mode dampener should be installed to eliminate "crank whip". What is crank whip? Can you hear it and if you can hear it what does it sound like? I think there are many different brands of dual mode dampeners. I can think of at least two, BAT and the Ford, unless they are both the same.
Thanks
Posts: 159 |
Which is a better mod, DMD or Underdrive Pulley?
Posts: 1,444 |
Originally posted by DavidD: Which is a better mod, DMD or Underdrive Pulley? David your on two different ends of the spectrum. The DMD reduces crank whip while an underdrive pully may increase your HP a few. Underdrive pulleys may INCREASE crank whip. So...just depends what you want. Maybe 3hp or engine life. It's up to you.
Posts: 3,248 |
I guess a dual mode dampener should be installed to eliminate "crank whip". What is crank whip? Can you hear it and if you can hear it what does it sound like? "Crank whip" is crankshaft bending/flexing that occurs especially at high RPMs. It causes premature bearing wear which can lead to spun bearings and broken rods. It is a particular problem in the Duratec as I understand because Ford shortened the crank from the original (Porsche) design without propererly compensating for it. The dual mode damper is the compensation, developed by Ford's OEM damper supplier to fix the problem (it is now found as OEM on new Duratecs equipped with the MTX). You can feel crank whip..the Duratec is pretty smooth but install a DMD and you will realize that the high RPM band is now noticeably smoother. My advice,,just do it.
1999 Amazon Green SVT Contour (#554/2760) Stock SVT Duratec V6 with: Intake- K&N filter/75mm MAF meter Exhaust- MSDS Y-pipe/Bassani catback Durability-Ford "dual mode" damper, Mobil 1/K&N oil filter 179.2 FWHP at 6900 RPM
