#22185 06/27/02 05:48 PM
W
Wiser Offline OP
W
How many of you have installed the dual mode dampener on your SVT? What band did you use? What are your reasons why you installed the dual mode dampener? If you do not have one installed, are there any reasons why?
Thanks
#22186 06/27/02 06:18 PM
F
F
do it cuz Terry told you to do it, nuff said.
hehe j/k laugh
Kim
2001 Mercury Cougar C2
1995 Contour GL
Quote: Originally posted by shotwell:
Yeah, I keep checking too. I'm afraid that just as the site goes down my car will burst into flames or something (knocking rapidly on wood)!
#22187 06/27/02 06:29 PM
Thanks
Because I'm waiting for the one I ordered to arrive at Elky's house. laugh
Everyone is willing to help me in past tense.
#22188 06/28/02 11:18 PM
crank whip....
#22189 06/29/02 12:57 AM
"What band did you use?" Care to explain that one better?
The Dual Mode Damper lessens the tendancy of the crank to "bounce" around in its bearings, which isn't good for bearing life. The difference you will notice is a much smoother feel in the higher revs.
#22190 06/29/02 01:40 AM
just do it.
AL
Red '98 SVT E0 3098/6535
KKM, Elizabethan EGR Plate, TH fix
OMP front brace
Hightower rear brace
DMD
B&M with reverse lockout disabled and centering spring removed
Mobil 1 oil and trans fluid
A6 Side Markers, Optima orange, Horn recontent
Painted Sail Panels
VooDoo Knob and pedals, RogerR deadpedal
Blau Houston & CD changer
Cup holders that work
Donnelly mirror
BAT Sill Plates
and a Bullitt fuel door
#22191 07/01/02 02:55 PM
W
Wiser Offline OP
W
I guess a dual mode dampener should be installed to eliminate "crank whip". What is crank whip? Can you hear it and if you can hear it what does it sound like? I think there are many different brands of dual mode dampeners. I can think of at least two, BAT and the Ford, unless they are both the same.
Thanks
#22192 07/01/02 02:58 PM
Which is a better mod, DMD or Underdrive Pulley?
98 SE Duratec/MTX Plain Jane (for now)
98SVT #231/6535 Stock
www.pbase.com/ddehoyos/svt
#22193 07/01/02 03:14 PM
David your on two different ends of the spectrum. The DMD reduces crank whip while an underdrive pully may increase your HP a few. Underdrive pulleys may INCREASE crank whip. So...just depends what you want. Maybe 3hp or engine life. It's up to you.
#22194 07/01/02 03:38 PM
"Crank whip" is crankshaft bending/flexing that occurs especially at high RPMs. It causes premature bearing wear which can lead to spun bearings and broken rods. It is a particular problem in the Duratec as I understand because Ford shortened the crank from the original (Porsche) design without propererly compensating for it. The dual mode damper is the compensation, developed by Ford's OEM damper supplier to fix the problem (it is now found as OEM on new Duratecs equipped with the MTX). You can feel crank whip..the Duratec is pretty smooth but install a DMD and you will realize that the high RPM band is now noticeably smoother. My advice,,just do it.
1999 Amazon Green SVT Contour (#554/2760)
Stock SVT Duratec V6 with:
Intake- K&N filter/75mm MAF meter
Exhaust- MSDS Y-pipe/Bassani catback
Durability-Ford "dual mode" damper, Mobil 1/K&N oil filter
179.2 FWHP at 6900 RPM
