DOHC (Dual OverHead Cam)s are normally associated with 4 valve-per-cylinder head designs where you have a cam off to one side for the bank of intake valves on that side of the head and a second cam for the other bank of exhaust valves on the otherside of the combustion chamber. SOHC (single) is usually associated with 2 valve per cylinder designs, since there doesn't have to be near as many different cam lobes (i.e. fewer valves). 4 Valve per cylinder engines were invented because of their wider powerbands, since the primary intake valves and intake runner diameter and length can be tuned for low RPM power, while the secondary intake valves and intake port runner diameter and lengths are tuned to come on (with aux. computer controlled throttle butterflies) only at higher RPMs, thus making the motor more powerful and efficient throughout a wider operating range. The advantage to having the 2 exhaust valves in each cylinder is because goemetrically speaking, 2 smaller diameter exhaust valves fit better in a round cylinder, and can flow more air than one big valve, because the big valve can only be so big before it would physically interfere with the intake valve's position in the combustion chamber. Did I make sense?
'95 CONTOUR SE
-Enkei 16s
-Porsche944 Exhaust tip
Audi xenon projector headlights
-Peterbilt 30" air horns
-mp3 Aiwa headunit (150 songs on one disc)
-dual 10s
-soon to have LED tailights (real kind, not just gay bulbs)
-That's it for now
