It looks like the manifold creates a low pressure chamber directly above the head inlet ports that allows the engine to better pull in the intake air charge.
Instead of pulling it through the entire intake tubes at high rpm (slows velocity), it allows it to pull in air from a low pressure zone very close to the head ports. This way it raises high rpm engine efficiency and therefore it's power & the powerband.
I've seen atleast one Duratec engine (racing of course) that has the LIM opened up and joins the 2 ports (primary & secondary) about where the butterflies used to be. Then it also opens the head ports by joining them together before they split back up at the valves.
This creates a small expansion chamber right at the fuel injectors which accelerates the intake charge and raises high rpm power. Plus as a bonus both valves distribute the fuel & air charge instead of just the primary port.
This is definitely in my bag of tricks if and when I ever do a 3L hybrid...
