Wooooo Turbo ehhhhh I mean boost man  There is no love taking from your Speedo reading! What your speedo said is INCREDABLE I got almost 160 on my ZX-6 when I had her... I know that to is incredable, but not as good as yours!! I was wondering kinda and the same with eric what the actuall speed would be compared to the speedo to get a gestamation. This is in no way to take away from what you did! Mad props to you. I will leave it at that for you know your the pimp of the top end speed! I don't plan on challeging you in any top speed run! Originally posted by PhatSVT: as i have said repeatedly that it was bouncing off of the 160 mph mark. if you look at your guages you will see that there is the reset button right at the 160mph mark. it was bouncing there for it was trying to brake through that. i would say 165mph to 170mph if it would have registered. the guy that was following me said i was easily over 150mph. so that 145 is bull****. come on try to burst my ****ing bubble some more. so **** off.
Merlin
281hp 324tq Timing 14' FP 36,24lbs,190lph,75Maf,65tb,cobra upper&lower,B303, GT-40 Crate with X al heads, Mac shorties, Off Road H,2chamber Flow's dumped, Tokico 5wys, Hotichkis Ctrl Arms, Alum Drive shaft, 3.73, Sub Frame,Steeda Tri-Ax, 94 Seats Drivers side powered.
