#21203 06/21/02 02:32 PM
Ok my water pump pulley is pushed on about an inch to far and I need to get it to come out. Has anyone rented a puller that would be able to get the water pump pulley off. I went to my local auto parts store and they don't have one that will work. Throw out any ideas because I really wanted to get this SVT engine in today.
Thanks,
Chris
Here are a few pics so you can figure out what I mean:
pic 1
pic 2
1999 V6 MTX Black Cougar
Jacobs ignition system, Borla dual exhaust, Sho shop y pipe and hi flow cat, gutted precats with MIL eliminators, IAT rewire, vitek ignition wires, SCA CAI with monster flow filter, Unorthodox racing pulley, BAT rear strut brace, Battery relocation to trunk, eibachs, KVR crossdrilled/slotted rotors, freedom design strut brace and Tuned S-AFC
Waiting to be installed:
svt engine with 11k miles on it/ fidanza flywheel/Quaife/energy suspension engine mount inserts.
#21204 06/21/02 05:47 PM
Something isn't right in there. There really isn't any way to move that pulley that far in unless someone beat it with a hammer or something. Everything should line up just fine if that was a complete motor you bought. Are you sure that the cams are in the right location in the bearing mounts in the head?
I wouldn't try to use a puller to get the WP into the right location. Proper way would be to support the pulley all around and press the shaft down. I'd have a machine shop probably look at this one. If you bend the pulley at all with a regular 3 jaw puller (which would be extremely easy) your belt will not lost very long and shred itself repeatedly from the pulley being out of whack.
HTH and sorry for the bad diagnosis,
Rick
The first Blown 3 Liter!
"Drive it till the wheels fall off" -my personal motto!!!!
98.5 T-Red SVT #6180
Many Mods
Buckshot77@aol.com
Owner of 00 #1611 Silver
Totalled on 10/7/01
SVT Parts for Sale
#21205 06/21/02 08:39 PM
How did it get so rusty too???
That's pretty unreal for an engine only a few years old and under a hood.
Did you get to see the car it came out of? Maybe massive front end damage and the place banged on another pulley from an older Duratec???
Like Buckshot said. It takes a special press to install and remove those and the cam has to be out of the engine.
Something definitely isn't right...
2000 SVT #674 - Check it out!
#21206 06/23/02 04:01 AM
H
H
Pic 2 seems to show wp pulley to far out (ie towards driver's side). I can't see wp shaft on my cars and with two wp replacements in May I've become very familiar with this component.
New wp maybe the way to go.
stock CD on LS, cass on LX
4 wheel discs on LX only
