Posts: 32 |
i'm replacing all four brakes this weekend with the budget kit from BAT (basic rotors and mintex a/f pads). any suggestions/things to look out for? the haynes manual seems rather minimal and i've only done gm truck brakes before.
1995 Mercury Mystique GS 2.0L Zetec, MTX 10% dents all around its not my fault its teal!!! it was cheap!
Posts: 345 |
Get some Permatex Disk Brake Quiet to spray the backs of the pads, and get Permatex Ultra Disk Brake Caliper Lube to grease the slide pins.
AL
Red '98 SVT E0 3098/6535 KKM, Elizabethan EGR Plate, TH fix OMP front brace Hightower rear brace DMD B&M with reverse lockout disabled and centering spring removed Mobil 1 oil and trans fluid A6 Side Markers, Optima orange, Horn recontent Painted Sail Panels VooDoo Knob and pedals, RogerR deadpedal Blau Houston & CD changer Cup holders that work Donnelly mirror BAT Sill Plates and a Bullitt fuel door
Posts: 587 |
Originally posted by goldsmi: Get some Permatex Disk Brake Quiet to spray the backs of the pads, and get Permatex Ultra Disk Brake Caliper Lube to grease the slide pins. dayum.... 'nuff said.. Ray
Posts: 13 |
Is Haynes a good service manual or is there a better one? Off topic... Sorry
I'm a high school student with little to no money. I have a 98 Contour SE w/ 2.5L 24v V6 w/ 100k miles. I'd like to make some cheap performance upgrades <$1000 or so. I only spent 4k on the car. Mainly, I HATE Honda Civics and I want to blow them away. I usually can anyways! Any suggestions please e-mail me. devonb_37@hotmail.com
Alpine 240W CD receiver 4 Pioneer 6x8 3-ways. Yokohama Sport tires
Posts: 249 |
I need to replace my brake pads this weekend also. Can someone please tell me where I can get some mintex brake pads from?
Thank You
~~~~~~Mike~~~~~~ Silver 2000 Contour SVT # 1200 of 2150
Posts: 1,367 |
Originally posted by SVTMike: I need to replace my brake pads this weekend also. Can someone please tell me where I can get some mintex brake pads from?
Thank You spmotorsports and BAT sells them (SP gets theirs from BAT). you could also just go down to your local auto parts store and pick up a set of bendix pads. they're not too bad for the price. EDIT: http://www.spmotorsports.com/contour_brakepads.html
Posts: 587 |
Originally posted by RandallRaines: Is Haynes a good service manual or is there a better one? Off topic... Sorry Asking that question here (which someone has, a lot of times) will get you mixed results.. Here is a SEARCH result for "Haynes".. Chilton\'s or Haynes HTH Ray
Posts: 3,419 |
Haynes is good for brakes. It really is as easy as they make it seem. The only thing that might get you in trouble is getting the old rotors off. Mine were very stubborn. The other big tip I have is to do one wheel without disturbing the other. That way, you can check to see how everything goes back together. You don't have to, but it's probablty a good time to flush the old brake fluid while you are down there as well.
Posts: 4,528 |
Might have a problem getting the rears off. I had to use an impact wrench to get those torx bolts off. Why Ford used them there is more than I'll ever know. Why isn't this in brakes area?
