#21030 06/20/02 01:31 AM
i'm replacing all four brakes this weekend with the budget kit from BAT (basic rotors and mintex a/f pads). any suggestions/things to look out for? the haynes manual seems rather minimal and i've only done gm truck brakes before.
1995 Mercury Mystique GS
2.0L Zetec, MTX
10% dents all around
its not my fault its teal!!! it was cheap!
#21031 06/20/02 02:04 AM
Get some Permatex Disk Brake Quiet to spray the backs of the pads, and get Permatex Ultra Disk Brake Caliper Lube to grease the slide pins.
AL
Red '98 SVT E0 3098/6535
KKM, Elizabethan EGR Plate, TH fix
OMP front brace
Hightower rear brace
DMD
B&M with reverse lockout disabled and centering spring removed
Mobil 1 oil and trans fluid
A6 Side Markers, Optima orange, Horn recontent
Painted Sail Panels
VooDoo Knob and pedals, RogerR deadpedal
Blau Houston & CD changer
Cup holders that work
Donnelly mirror
BAT Sill Plates
and a Bullitt fuel door
#21032 06/20/02 02:38 AM
Ray Offline
dayum.... 'nuff said..
Ray
Check out my car!! (Profile Registry)
Have a Nextel two-way? check out my registry for my number!
Ray Haralson
Jacksonville, FL
s_r_haralson@sar.med.navy.mil
srh@texas.net
YIM: midnghtflm
AIM: midnghtflm
NEWEST MOD: a BEAUTIFUL girlfriend for my one and only passenger.
#21033 06/20/02 02:52 AM
Is Haynes a good service manual or is there a better one?
Off topic...
Sorry
I'm a high school student with little to no money. I have a 98 Contour SE w/ 2.5L 24v V6 w/ 100k miles. I'd like to make some cheap performance upgrades <$1000 or so. I only spent 4k on the car. Mainly, I HATE Honda Civics and I want to blow them away. I usually can anyways! Any suggestions please e-mail me. devonb_37@hotmail.com
Alpine 240W CD receiver
4 Pioneer 6x8 3-ways.
Yokohama Sport tires
#21034 06/20/02 03:05 AM
I need to replace my brake pads this weekend also. Can someone please tell me where I can get some mintex brake pads from?
Thank You
~~~~~~Mike~~~~~~
Silver 2000 Contour SVT
# 1200 of 2150
#21035 06/20/02 03:54 AM
Thank You
spmotorsports and BAT sells them (SP gets theirs from BAT). you could also just go down to your local auto parts store and pick up a set of bendix pads. they're not too bad for the price.
EDIT:
http://www.spmotorsports.com/contour_brakepads.html
-Dan
1998.5 SVT "Black and Blue" #5292
See here for MOD list.
"Washing your car to make it rain does not work."
#21036 06/20/02 04:24 AM
Ray Offline
Off topic...
Sorry
Asking that question here (which someone has, a lot of times) will get you mixed results.. Here is a SEARCH result for "Haynes"..
Chilton\'s or Haynes
HTH
Ray
Ray Haralson
Jacksonville, FL
srh@texas.net
YIM: midnghtflm
AIM: midnghtflm
#21037 06/20/02 04:33 AM
Haynes is good for brakes. It really is as easy as they make it seem. The only thing that might get you in trouble is getting the old rotors off. Mine were very stubborn. The other big tip I have is to do one wheel without disturbing the other. That way, you can check to see how everything goes back together. You don't have to, but it's probablty a good time to flush the old brake fluid while you are down there as well.
#21038 06/20/02 03:17 PM
Might have a problem getting the rears off. I had to use an impact wrench to get those torx bolts off. Why Ford used them there is more than I'll ever know. Why isn't this in brakes area? confused
"If you're pushing crazy I'm all full up here."
{Black '96 Contour SE MTX w/ over 126k on the clock}
· Get the skinny here.
· Need a 96-00 Ford Service Manual on CDROM?
