Page 2 of 2 1 2
#161812 06/07/02 05:57 AM
i apreciate all the info.
it makes sense, can anyone confirm this?
another alternative for me would be putting the 17lb injectors back in. my only concern is...would i be running lean at fuli throttle or would i be just fine?(with the injectors at its max or almost)
mods:
headers
foam filter
SVT UIM and LIM
SVT head assembly with cams
Borla
#161813 06/08/02 05:12 PM
kid where'd u get the svt cams
95 contour se...dark blue...monsterflow air filter...remanuf atx...wiring harness recall or bust!!!96k miles...motorcraft awsf32pp plugs & red ford racing 9mm wires...kvr black plated cross-drilled rotors & carbon fiber pads...currently undergoing renovation...excuse our dust!!!
are my dodgers for real????
#161814 06/08/02 08:18 PM
bought them used, it was a bargain $330 for 2 whole heads.
also i put the stock injectors back in and it idles smoother and the starts are much better. no check engine light yet but its only been 30 miles, just gotta wait i guess.
#161815 06/12/02 07:05 AM
Originally posted by Chow:
Well I got a Pro-Flow 75mm MAS that I'm not using.
Let me know whats up
Chow, how much do you want for it?
$1,000.00?
I'll give $2.00 bucks : P
99 COBRA
19" HRE's
cleaned up stock intake
BBK LT's VRS X PIPE W/CATS
Magnaflow cat-back
removed air silencer w/K&N
in line 47k resistor
cobra r bilsteins w/KB springs
MM sub frame's
MM STB
http://www.mustangworld.com/ourpics/News/select1602.htm
SOLD 99 SVT CONTOUR
Page 2 of 2 1 2
Moderated by  Fmr12B_dup1, path914
