#161669 04/22/02 03:40 AM
i just bought a 1998 contour SVT, and i was warned about the cheap plastic water pump which breaks so easily...how often should i change the water pump? Where can i buy them and how much do they cost?
#161670 04/22/02 05:15 AM
you just need to change from the plastic to the metal impeller WP once. I haven't heard of anyone's metal WP falling apart yet. Available at AutoZone
#161671 04/22/02 07:01 AM
The reason why the metal ones don't fail as much as the plasic ones is because the back part of the water pump falls apart internally. This metal ring that falls out puts pressure against the impeller causing it to crack and fail. Using a metal one and it shouldn't fail. But the back part will most likely fall apart.
I've had three water pumps that 'fell' apart since I've owened the car, none of them acutally broke but there was serious wear and trear to the impeller because of that metal ring coming apart. My susggestion is to buy a new water pump from Ford because it includes a new housing.
Or you can buy a new metal pump like everyone else laugh
David Zambrano
svt_mondeo at yahoo dot com
CSVT E1 #4808 - soon to be 400hp
You get what you pay for. All advice here is free.
http://www.geocities.com/svt_mondeo- my homepage
Moderated by  Fmr12B_dup1, path914
