#161553 03/31/02 04:59 PM
my horn went out does anyone know where the horn location is please vhelp thanks
00 svt contour
black
B&M shifter
#161554 03/31/02 09:04 PM
Is your air bag light flashing, and do you have cruise control working? If cruise is not working and you have airbag light, you have a clock spring problem. Unless you are comfortable with removing the airbag (after disconnecting your battery for 20 minutes), take it to the dealer. Actually, if you have a 2000 you are probably still under warranty.
Jim
98.5 SVT, Vortech SC, Bassani, Quaiffe, Clutchmasters Stg. 3, BAT Sport Springs/Konis, 17" Momo Arrows, Sparco Brace,BAT 22mm Sway Bar, PIAA fogs & headlights.
#161555 04/01/02 05:23 PM
The horn is on the driver side, right under the battery. You would need to go from the bottom, remove the underbody panel (8 nuts) and you'll see it. Look towards the open space near the driver front wheel.
#161556 04/01/02 08:21 PM
Busted Horn, watch for finger bumper sticker comes to mind smile
David Zambrano
svt_mondeo at yahoo dot com
CSVT E1 #4808 - soon to be 400hp
You get what you pay for. All advice here is free.
http://www.geocities.com/svt_mondeo- my homepage
#161557 04/01/02 11:39 PM
E
E
Eeewww. I don't like that idea. My horn is dead, so is my cruise control. frown My airbag light is still off though. laugh
I am going to test the circuit at the horns though. Mine took on water a long time ago and sounded sick after that. All of the sudden they died.
· Jon Miconi
· 96 Contour Zetec ATX
· 80 Ramcharger 360 ATX
· 77 Ramcharger 440 ATX
Moderated by  Fmr12B_dup1, path914
