Page 2 of 2 1 2
Lee Offline
"You boys just ain't right."
Lee Cox
In life begins responsability...
Project Car
ohh man, my poor bearing.... well at least it came out. hack or no hack..it still worked smile
Mike | 98 Silver CSVT
I had to do one last fall and it cost me about $55 CDN at the Ford dealer. The reason? About 2-3 months earlier, I beat a little too much on the rotor trying to get it off. I ended up cutting it off. Saved the other bearing by cutting the other rotor off too. Man do they seize on there. A shop press would be the way to go but is not necessary. I used a heat wrench (torch) to take the bearing off the hub. This is something you have to know how to do to not heat up or damage the hub. It's definately not an easy job changing a wheel bearing on these cars. REMEBER: WHEN YOU BEAT ON YOUR ROTORS, YOU'RE ALSO BEATING YOUR BEARINGS and that's why everyone's now replacing bearings.
Ray
New Brunswick,CANADA
99 SE Sport ; T-Red ; 2-tone Gray Interior ;
Zetec ; ATX ; 885 fogs ; [ no ABS smile ]
65w 9005 ; 55w 9006 ; my headlight fix (aim beams separately)
V
V
anyone have a pic of the proper tool to remove hub bearings? I need to go borrow one and need to some what be able to recognize it and ask for it. thanks again.
with proper tools and all think 2 hours will suffice for a rookie?
if you're bored, here is some info on my slug...
http://members.cardomain.com/trade4mondeo
Page 2 of 2 1 2
