Stephen Offline OP
I'm reading the Haynes manual about the transaxle and it talks about Economy and Sport mode but does not tell you how to change the mode.
Does anyone know how to change the mode?
From the manual;
"There are two operational modes (Economy and Sport). With the Economy mode selected, gear changes occur at low engine speeds, whereas with the Sport mode selected, the changes occur at high engine speeds."
It would be cool if someone knew how to switch the CD4E to Sport mode.
Stephen
96 Contour, GL, Zetec, ATX.
03/18/1996 Build Date.
Drop in K&N
NGK Laser Platinum Premium Spark plugs
Niehoff Premium Ignition wires
Wheel Well Air Intake Resonator removed.
*Just the beginning*
V
V
Interesting...And I saw a 'Sport' light on the dash too yesterday next to the O/D light.
Midnight Red '95 Contour SE ATX
Just completed the lighted moonroof switch mod. Its great!
www.webcentrix.org/contour_se.html
"The whole purpose of a car is not to go fast it's to get from point A to B, and if you can afford it, to get from point A to B with some sense of style."
As seen on the Ricecop.com boards
I think it has to do with how far the gas pedal is pushed. Changes modes by itself. When you have the pedal all the way down, the motor revs to redline, when you dont, it shifts sooner. Correct me if Im wrong, someone. laugh
-Ken V.
psycho_bass@hotmail.com
My Car
Ray Offline
That is a typical ATX for you.. in any car. You push it harder, it waits longer... That isn't what they are referring to, I don't believe.
BTW: nice sig VA_Tech. Style is what its all about.
Ray
Check out my car!! (Profile Registry)
Have a Nextel two-way? check out my registry for my number!
Ray Haralson
Jacksonville, FL
s_r_haralson@sar.med.navy.mil
srh@texas.net
YIM: midnghtflm
AIM: midnghtflm
NEWEST MOD: a BEAUTIFUL girlfriend for my one and only passenger.
9
9
This would definitely be cool to look into...
Anybody???
1999 CONTOUR SE SPORT
2001 HONDA CIVIC LX SEDAN
- 1.7L 5 Spd
- '02 SI RIMS
- Reverse Indiglo Gauges
"Biblical principles work, there are no exceptions."
www.geocities.com/jesusfr7282000
http://www.7thgencivic.com/members_rides/member.cfm?id=5895
my ex had a 91 probe with economy and sport modes which was activated by pressing a button on the gear **** lever
i think on these cars the overdrive is basically the same thing...
with o.d on u're in econo mode with it off u're in sport mode
i dont have a sport mode button or light per se but usually just click in and out of od as needed
95 contour se...dark blue...monsterflow air filter...remanuf atx...wiring harness recall or bust!!!96k miles...motorcraft awsf32pp plugs & red ford racing 9mm wires...kvr black plated cross-drilled rotors & carbon fiber pads...currently undergoing renovation...excuse our dust!!!
are my dodgers for real????
F
F
The Mondeo's have both an Overdrive and Sport Mode switch... so they seem to be two different things.
2000 Mercury Cougar V6 ATX. 16.0@87MPH, 155.0 FWHP
I think the Haynes' wording is off. I think the stuff in the trans section refers to O/D on/off (even though they say "Economy" and "Sport"). The Mondies had/have a "Sport" setting for the suspension. Computer actively sets the shocks stiffer for "sporty"driving and you can turn it on and off. Like we would ever drive around with that off if we had it. :rolleyes:
Check out the Suspension chapter; they have a few mentions of it in there.
i just wish i had a stick, then I would decide how the car car was going to be driven smile
STD's are like Pokemon...
Gotta catch em' all!
Q
qaz Offline
Q
On the 1995 EEC-IV PCM, there is a pin that is unused in the US version that is what the economy/sport switch is connected to.
I doubt that the software to support it is in the '95 PCM, let alone the 96-newer EEC-V PCMs.
Not that you could even find out, since the design of the EEC-IV connector on the '95 makes it difficult, if not impossible, to add female terminals. frown At best you'd have to do some drilling...
Brian
