V
ValCor Offline OP
V
Very simple job after I took a peek under the car. Did not need a floor jack after all. Had to go to Pep Boys, two Kragen stores, and finally to a Ford parts counter to get all the mounting "hardware". Most of the cheap nylon (plastic) mounting screws and plugs could not be reused. I left the skirts unpainted and they look great. I may order a spare set. Who knows just how long they will be available? I could always sell them to a fellow CEGer if I don't need them. I figure 120 bucks is not bad since I plan on keeping the car for as long as it lasts.
1998.5 Contour SVT - Silver Frost Metallic/Midnight Blue - 64K miles.
you know what i was thinking?
things should be given away, mainly to me
that'd be nice.
cause i sure as hell cant afford anything anymore
-jason
congrats on the install!
i heard last night that they're having the car show again at work, are you going to enter your SVT? laugh
Todd Christ SVT Contour Registry
MODS: KKM Intake, SHO Shop Y-Pipe, Bullit Fuel Door, Edelbrock RPM Resonator
'98 E0 SVT Contour #1037 of 6535
V
ValCor Offline OP
V
Nah! Don't want folks oohing and aahing all over my ride. Besides, my car isn't old enough to be in the show, is it?
why'd you install new side skirts?
i just reinforced my side skirts the other day...stainless steel sheet metal screws seemed to do the trick wink Nearly all the old screws had fallen out on my driver's side. eek
2000 Silver SVT #1602
Check it out in the registry!
Mi Coche
sure it's old enough! my buddy had his '96 WS6 trans-am in it last year! smile
V
ValCor Offline OP
V
My skirts were beaten up on both sides. I ran over a couple of traffic cones almost two months ago and they took out a nice chunk of side skirt on my driver side. The passenger side front jack port cover was also damaged and held in place with duct tape. So, I decided to replace them both since they were cheap enough. The new ones look nice, even unpainted! Why unpainted? Expensive! Besides, I like the new look.
Moderated by  Fmr12B_dup1, path914
