Posts: 2,260 |
The spark plug just came out for the second time in the same cylinder. Am I missing something here? Can this really be a problem with the spark plug itself? The threads look fine. I am tired of having to walk home and leave my car in a parking lot. James
SVT with CE light mod and a camera mount. Naughty Pictures Why yes it is true, I am on my third engine.
Posts: 256 |
I say 5 cylinders is better than none, just drive it anyway
Black '98 SVT Contour Clear headlights Door ding guards removed 15% tint all around 5 in. LCD and DVD player K&N Intake
When a cat is dropped, it always lands on its feet. When toast is dropped, it always lands butter-side-down. I propose to strap buttered toast to the cat's feet, butter facing up. The two will hover, spinning, inches above the ground. With a giant buttered-toast/cat array, a high-speed monorail could easily link New York with Chicago.
Posts: 926 |
[cough] Lemon [/cough]
Ben C '97 Zetec Sport ATX Pacific Green Fog Light Re-wire Many Mods My Site
You think you can beat this?.....Well, you probably can
Posts: 1,038 |
how does it just come out? like you pulled it out? or it unscrewed? i'm lost
good luck with it though. I'm amazed you still have the car after all you've gone through.
-jason
Posts: 2,260 |
Originally posted by Stinger00: how does it just come out? like you pulled it out? or it unscrewed? i'm lost
-jason Like I heard that damn popping noise when I started the car up, popped the hood and the end of the spark plug is probably lying about 1/4 inch in the head at an angle http://www.contour.org/forums/ultimatebb.php?ubb=get_topic;f=1;t=014254
Posts: 118 |
sounds like the person who said that your socket was stripped was right.. either that, or your mechanic needs to learn the "Righty tighty, lefty loosey" rule.... You may want to check to see if he screwed in the bloddy thing next time....
Personally, I'd put a clean finger into the hole that the spark plug goes into, and see if there are any threads there for the plug to grab onto... or use silly puddy to make an impression....
1998 E0 Contour SVT #2478/6535 B.O.D. Wed, 07/16/97 P.O.D. 09/14/97 Black/Midnight Blue Mods: - Diablo Chip (RJL1) - K&N Air and Oil Filters - Ultrawhite headlights, Sylvania 885 foglights - Mobile 1 Synthetic - Panasonic CD-DF801U, Autotek 4160 amp, Neo 35 MP3, Lanzar NEO8 and VX572's - limo tinting
Posts: 118 |
Ford: Quality is Job #1. I love owning a Ford sometimes. :p
2001 ATX V6 Dark Shadow Grey Merc Cougar(Sport Pkg, ABS, traction control and sunroof :))
Posts: 2,906 |
Seeing how you are so mechanically inclined, why don't open your damn hood and check them with a spark plug socket. Its not rocket science ya know! Almost as easy as checking your oil...no wait, you don't do that either?! :rolleyes:
Josh Aka Spectra SVT 02 Dark Highland Green F-150 XLT Mods: Gunrack and cowboy boots
Posts: 2,260 |
I got a spark plug socket, just can't get the right angle for the back cylinders :p
Posts: 2,166 |
I think your fux0r3d
Try some superglue
