Posts: 645 |
1 right hand hwy entrance + getting on the gas = oil starvation and thrown rod  Sucks!!!!!! I'm hoping it is still covered under the powertrain warranty.
Chad ----------------- http://www.1dzine.com jetski@mindless.com 98.5 SVT ? KKM Tru Rev ? Glasspack instead of resonator ? Dyno Max Super Turbo Muffler w/Brospeed 3.5" Rolled tips ? Brembo/KVR Cross Drilled Cadnium Front Rotors and KVR Carbon Brake Pads ? Blown Engine Replaced @ 41K
Posts: 2,906 |
ouch...I do this all the time...scary
Josh Aka Spectra SVT 02 Dark Highland Green F-150 XLT Mods: Gunrack and cowboy boots
Posts: 645 |
Yeah it is scary, I always thought I would be ok, but I guess not. Not covered under warranty. Looks like I have some thinking to do on the Contours future.
Posts: 1,038 |
oh lord. was it an onramp around here in pleasanton? i better be careful.
good luck. in warranty?
-jason
Posts: 645 |
Nope no warranty. It was down in Sunnyvalle. About a good 5 second on ramp to 101 from 237. I was following an A4. Needless to say I bet he is not having the same problem right now!
Posts: 2,260 |
If you need help finding another engine I know of a place in La that sells SVT engines with a warranty.
James
SVT with CE light mod and a camera mount. Naughty Pictures Why yes it is true, I am on my third engine.
Posts: 425 |
Originally posted by Coors: 1 right hand hwy entrance + getting on the gas = oil starvation and thrown rod
Sucks!!!!!!
I'm hoping it is still covered under the powertrain warranty.Damn. I'm going to regularly check my oil level every day or two now, and keep it at 6 qts. I don't want this happening to me...
I heed the call of the curb
Posts: 645 |
Originally posted by British Banger: If you need help finding another engine I know of a place in La that sells SVT engines with a warranty.
James thanks James. I'm supposed to get an estimate tomorrow. Not sure if I wrecked the block or not. It seized up but not all the way. It would still turn over, just wouldn't start with that knock in there. By the way, are you all back together now?
Posts: 645 |
Originally posted by Xeno-tour:
Damn. I'm going to regularly check my oil level every day or two now, and keep it at 6 qts. I don't want this happening to me... Good idea. I think regardless of the outcome, I'm going to put an aftermarket oil pan in for added security.
Posts: 2,260 |
If you don't mind you can send me a PM when you get the estimate just to make sure everything's fair and in order Where are you getting it fixed? James I'm getting the mirko pan insert, it's a good idea
