Posts: 31 |
Thanks guys. I guess I should have underlined easy. I know hp isn't cheap. I guess really I would just like to rev to 7200-7300 rpm. Power is good and still flowing when I run into the 6750 mark. Getting another 500 rpm would make my driving vundabar. The motor is tweaked as you say from factory, so maybe exhaust and a chip will be all I want to venture. I LMAO when I heard the term fart cans. So in summation: will a superchip raise the fuel cut off point (vs the term rev limiter)?
98 EO Silver Frost SVT, K&N, Eibach springs, 225x50-16, tinted. #3867 of 6535 Replacement for my 91 SHO.
Posts: 3,419 |
Originally posted by shoB4svt: So in summation: will a superchip raise the fuel cut off point (vs the term rev limiter)? Pretty much one in the same. IIRC rev limiter is accomplished by cutting fuel and spark.
Posts: 23 |
Who wants to answer a question for a goober? Anyone? Anyone? Will chip burned for 2000 SVT work on 98 2.5 'tour without reprogramming? EXPENSIVE!!!!!
Posts: 613 |
okay to answer the question on rev limiter, I have a nun1 code on my car and with the chip, lets just say that I now can run a quarter mile in 3rd gear... It raises up as much as you are looking for and maybe a bit more, I havent taken it over 7500 so Im not sure when it bounces, Im afriad to even take it that high  but in summary, the chip, especially the superchip from superchips.com will do what you want.
~~~~~~~~TRAVIS~~~~~~~~ Now driving: I MEAN NOT DRIVING---- 1995 Contour SE Maroon, MTX, sunroof w/rain-guard, neons, and audio replaced. Side Markers installed and headlight strobes also now on. *KKM tru-rev - I love it 9mm FMS blue wires SVT Upper SVT exhaust SUPERCHIP˛ custom ram air Newest mod = f***ed up engine, prolly shot, yeah
Posts: 7,329 |
Originally posted by Dan Pope: Who wants to answer a question for a goober? Anyone? Anyone? Will chip burned for 2000 SVT work on 98 2.5 'tour without reprogramming? EXPENSIVE!!!!! No. Cost is around $50-125 for a reburn. It pays to shop around. KKM does it for $50 IIRC.
Posts: 303 |
I thought that while redline is 6750, fuel cut-off isn't until 7000, so you should be able to spin to 7k. I can (or else my tach is a bit off).
Kerry
99 SVT Contour Silver Frost, #365/2760 91 Isuzu Impulse XS Kammback, Handling By Lotus Victoria, BC, Canada
Posts: 3,950 |
Originally posted by TheGSRGuy: 112mph on non-SVTs. Mine was about 108 on my Zetec. Got the chip and problem solved.
