#19598 06/11/02 03:29 PM
Hello all. This has been asked more than a few times, but, what is the easiest or cheapest way to squeak out another 20-25 hp from the CSVT? I already have a K&N drop in, otherwise engine is stock. On a similar performance note, can the rev limiter and fuel cut-off be raised with a chip or other? I sure would like to rev another 500rpm. Thanks.
98 EO Silver Frost SVT, K&N, Eibach springs, 225x50-16, tinted.
#3867 of 6535
Replacement for my 91 SHO.
Originally posted by TheGSRGuy:
Getting a chip will help a bit by raising the rev limiter to 7500 and removing the top speed governor.
We have a top speed governor now...DAMN.
Joey
2000 SVT Black
#1811 of 2150
Dad always thought laughter was the best medicine, which I guess is why several of us died of tuberculosis.
Yes. 143mph on SVTs, 112mph on non-SVTs.
Dan Parmelee
1999 Acura Integra SiR-G coupe
"I heard Affleck was the bomb in Phantoms"
"Word, bitch! Phantoms like a muhfuka"
The 143mph "limiter" is nothing other than wind drag. There's no mechanical limit...although redline is not far away at 143.
-Matt
No govener on CSVT that is drag limited. So if you get more hp you can go faster than that. But I am assuming not much because soon you would be rev limited.
Green 2000 SVT #1166
mods-K&N open air filter & Custom heat shield, Custom y pipe and 30 in resonator,DMD, arm rest heightened
http://www.geocities.com/savinoss/Cars.html
other cars-89 sable 197000 miles and still going-Wifes car 99 Mystique V6 5 spd
Yes. 143mph on SVTs,....
NO. SVT Does not have a speed governor (other than the laws of physics). Rev limiter, yes. A chip can raise that, depending on your PCM code. Without a Dual Mode Damper, I wouldn't go too much higher than 7k RPM personally.
20-25 extra hp from an SVT will take extensive modifications. There aren't too many cars with a higher specific output (hp/L) than the SVT, meaning it's tuned quite well from the factory. IIRC, the highest hp from a N/A 2.5L is in the ~185 fwhp range, which is about where your extra 20 - 25 hp would put you.
I've heard about "pinning" the butterflies, but remove them? How's mpg then? Is there sufficient fuel delivery at 7500 rpm with the chip. The SVT still wants to run past the 6750 redline - oooh I hate when it shuts down on me in 3rd gear on the freeway (my SHO would run up that extra 500rpm just nice for instant passes)... so the the chip is my ticket - is there a preferred brand? thanks again.
#3867 of 6535
+20-25 HP requires some careful tweaking. Several ways to go about it..I suggest
1) 7"-9" K&N filter on BAT adapter with screen ($80)
2) Custom cool air box & ducting (make it yourself)
3) Pro-M 75mm MAF meter ($175)
4) Optimize SVT throttle body and rubber air tube
5) Optimize LIM butterflies (or remove if you are good with custom dyno/laptop tuning of a chip - investigate carefully first)
6) Gut precats (free) or headers - more noise, investigate carefully first)!
7) High flow Y- pipe (get it ceramic coated!) ($250)
8) Upgrade resonator & mufflers or catback if you want to spend more ($200-$550)
9) Ford Racing wires & new plugs if you have ($65) greater than 35K miles along with new fuel filter
9) Last...Dyno tune ($100-150 per hour) with wide band monitoring A/F - custom burn a chip ($250 + custom program $125), EEC tuner ($450) best & soon avail. Apexi-SAFC ($300), Pro-M optimizer ($150) cheapest but least capability.
Above combo gives high probability of 185+ FWHP, about 20 over stock . Speed costs money..
Add Dual mode damper ($135 from THM) for reliability. Keep oil at full mark always, happy motoring!
1999 Amazon Green SVT Contour (#554/2760)
Stock SVT Duratec V6 with:
Intake- K&N filter/75mm MAF meter
Exhaust- MSDS Y-pipe/Bassani catback
Durability-Ford "dual mode" damper, Mobil 1/K&N oil filter
179.2 FWHP at 6900 RPM
Wow. Don't listen the GSRguy. He's clueless isn't he... eek
25HP from just exhaust (4-8HP), headers (6-10HP), and a drop-in (2HP)
If you are lucky it might get you close to 20 crank HP with an open air filter and the best results of the other 2.
...and the SVT has a speed limiter. :rolleyes:
We won't even get into the secondary comment at this point...
Yes a chip is the only way to raise the redline. Just make sure superchips has been able to do it for your specific PCM code. I think they have 100% coverage now???
Most are raised to between 7300-7500rpm
2000 SVT #674 - Check it out!
Yup
1991 GVR4
Lots of mods done.
