#3538 03/08/02 06:28 PM
Seamore Offline OP
My 95 se has developed a small leak around the oil pan, Probably just a worn gasket. So my brother calls Advance to get HIS(business discount) price and they told him $100 he almost fell off his stool! Does this sound reasonable, she just turned 100k and runs like a champ I really want to take care of this before it causes problems, especially with all the warnings about oil levels in the duratechs.
95 Teal Se 5 spd,duratech, loaded(except moonroof) no mods.
Lee Offline
fordpartsonline.com
1995 | Ford | Contour List Your Price
Gasket, Contour, Mystique $8.55 $7.23
Gasket, Contour, Mystique $28.02 $23.67
Lee Cox
In life begins responsability...
Project Car
They had to have looked up the wrong part number or something... That's waaaaaaaaaaaaay over priced, even for Advance.
Brad Noon
'99 SE MTX
3 point oh my God H.O. 179HP/178TQ
BNMotorsports Floormats, powder coating, TB optimizing, Gutted cats, etc
BNMotorsports is now the preferred distributor of Contour/SVT/Mystique Indiglo style gauges!!!
bnmotorsports@msn.com
If that is installed sounds good. If it is just the part it is crazy.
1996 Contour GL Sport, Zetec, MTX
1995 Contour GL, Zetec, MTX
I wonder if that is a gasket set?
Tony Boner
It sounds like the gasket AND the oil pan.
98.5 SE Sport badgeless, MTX, KKM, SVT exhaust with resonator intact.
1985 Z51 Vette with many mods. Only used when the Tour appears to be outclassed.
Its not both, but it sure is more expensive to be just the gasket. Call Bill Jenkins, that's where I got mine from. I forget how much, but not that bad.
Check back with them and tell them you only want the oilpan gasket. I bet that is an entire lower gasket set, thats not what you want. smile
Gasket may be your second problem, the first is who is going to change out that pan? That is quite a bit of work!
Bt
