#19549 06/11/02 03:16 AM
RWReece Offline OP
Would someone please run an Oasis Report on this vin: 1FALP67L1TK205997. Thank you.
96 Black SE
2.5L V6 ATX
#19550 06/11/02 04:20 AM
It looks like there is an error in the VIN. Check the VIN and I'm sure that someone will try again.
OASIS RESULT:
1FALP67L1TK20599
06/11/2002
00:19:01
Errors
VIN NOT FOUND VERIFY ENTRY
FIELD SERVICE ACTIONS
*EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
REPAIR HISTORY
NO REPAIR HISTORY ON VEHICLE
END OF OASIS REPORT FOR 1FALP67L1TK20599
Somehow the entire VIN did not transfer. I hope this looks better.
OASIS RESULT:
1FALP67L1TK205997
06/11/2002
00:23:20
VEHICLE INFORMATION
VEHICLE DESCRIPTION
1996 CONTOUR BODY STYLE
4 DR SEDAN SE ENGINE
2.5L EFI DOHC ENGINE CALIBRATION
612BR10A
TRANSMISSION
CD4E AUTO TRANSAXLE AXLE CODE
4G
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
08/23/1996 BUILD DATE
04/26/1996 SALE MILEAGE
WARNING MESSAGES
LESS THAN TWO DEALER APPROVED AWA REPAIR VISITS PAID TO DATE
01M07 CAUTION: MAY NOT NEED REPAIR; SERVICE ONLY IF CONCERN IS PRESENT.
PLEASE REFER TO DEALER LETTER FOR PROGRAM COVERAGE
HEATER BLOWER SWITCH - COVERAGE FOR 10 YEARS FROM WARRANTY START DATE OR 150,000
MILES OR 12/31/2001 IF VEHICLE HAS 150,000 MILES. COVERAGE TRANSFERS TO SUBSEQUE
NT OWNERS
99M03 CAUTION: MAY NOT NEED REPAIR; SERVICE ONLY IF CONCERN IS PRESENT.
UNDER HOOD WIRE HARNESS - ADDITIONAL COVERAGE
99M07 CAUTION: MAY NOT NEED REPAIR; SERVICE ONLY IF CONCERN IS PRESENT.
HEATER BLOWER SWITCH, RESISTOR AND ATTACHED WIRE CONNECTORS
*EXTENDED COVERAGES
REPAIR HISTORY
10/09/2001 DEALER: Vancouver Ford Inc
WARRANTY CLAIM NUMBER: 369509 ODOMETER: 066973M
PART NUMBER PART DESCRIPTION QUANTITY
LABOR OP
CONDITION CODE
CONDITION DESC
F7RZ 18578DA SWITCH ASY-HEATER 001 01M07B
F5RZ 14A411AA WIRE ASY MAIN JUMPER 001
66973 BURNED HEATER BLOWER SWITCH AND CONNECTOR. 0.5 REPLACED HEATER BLOWER S WITCH AND CONNECTOR PER 01M07.
END OF OASIS REPORT FOR 1FALP67L1TK205997
Jim Johnson
98 SVT
#19551 06/11/02 01:23 PM
Well... I don't want to be abusive... but...
Would you also run one for me ??
It is really important... I am buying a beater...
thanks !!
JM1BG2246N0508240
** CT - USA **
* 96 Contour Gl 2.0
5 Speed Manual / Clarion CD Change
8" Subwoofer & Sony Amp (LOUD !!)
The Cleanest !!!
* 92 Mazda Protege
5 Speed Manual / 1.8
* 94 Yamaha Virago 535
(better than Viagra !!)
#19552 06/11/02 01:45 PM
Could you run one for my 'Tour too?
1FAFP6631WK217621
Thank ye kindly smile
#19553 06/12/02 01:58 AM
ttt! smile
#19554 06/12/02 04:47 AM
thanks !!
JM1BG2246N0508240
Oasis is a Ford program. It does not provide a data bank for non Fords.
Jim Johnson
98 SVT
#19555 06/12/02 04:53 AM
OASIS RESULT:
1FAFP6631WK217621
06/12/2002
00:51:15
VEHICLE INFORMATION
VEHICLE DESCRIPTION
1998 CONTOUR BODY STYLE
2.0L EFI DOHC ZETEC ENGINE CALIBRATION
804AR10A
TRANSMISSION
1A
WARRANTY START DATE
11/29/1997 BUILD DATE
11/14/1997 SALE MILEAGE
WARNING MESSAGES
01M04 CAUTION: MAY NOT NEED REPAIR; SERVICE ONLY IF CONCERN IS PRESENT.
FUEL PIPE FILLER VALVE ASSEMBLY - ADDITIONAL COVERAGE TO 10 YEARS SERVICE OR
100,000 MILES FROM WARRANTY START DATE WHICHEVER OCCURS FIRST
01M08 CAUTION: MAY NOT NEED REPAIR; SERVICE ONLY IF CONCERN IS PRESENT.
FRONT SPRINGS - COVERAGE WILL BE IN EFFECT FOR 10 YEARS OR 150,000 MILES FROM
WARRANTY START DATE - PLEASE NOTE: SVT VEHICLES ARE NOT ELIGIBLE
*EXTENDED COVERAGES
REPAIR HISTORY
04/03/2002 DEALER: Bob Ferrando Ford Lincoln-Merc
WARRANTY CLAIM NUMBER: 032233 ODOMETER: 057023M
LABOR OP
CONDITION CODE
CONDITION DESC
F8RZ 5304AA KIT-FRT PRING RR SHA 001 01S23B
RECALL 01S23
END OF OASIS REPORT FOR 1FAFP6631WK217621
Jim Johnson
98 SVT
