Posts: 96 |
I have a 95 contour, and I know this sounds stupid, but how much oil does the 2.5 V6 hold? I did not get a factory manual with the car, so I have no idea. Also is there a better oil to run in these motors? I usually run synthetic in all my cars.
1995 Contour SE Fully loaded/Leather 2.5L V6
Posts: 1,861 |
The manual says 5.8 quarts. I use a full 6 quarts. Make sure to use 5W30.
Jim Johnson 98 SVT
Posts: 1 |
The 2.5 take 5.8 quarts of oil. the 2.0 are like 4 1/2 quarts or something, mobil 1 syn is the best oil out there (just my 2cents)
95 contour 2.5 intake,exhaust,removed res,bosch+4,racing wires, sidemarkers, racingstripes, --Superchip Blue module PEW4-- LoTek A-pilar gauge pod indiglo gauges
Posts: 1,861 |
Wow, a twin posting. Must have been only a split second apart.
Jim Johnson 98 SVT
Posts: 2,848 |
6 qts...it's safe to overfill to 6.5, and a good idea IMO
1999 Silver Frost SVT #609 of 2760 Born on 12/3/98
KKM Intake Removed Resonator 35% Window Tint all around Tinted Tail Lights ElKy Mesh Grilles HID
Dyno'ed at 175.3HP/155.5TQ
Posts: 3,584 |
I run 6.5 quarts of Mobil 1 after reading that post about the results that Roush got on our motors, less than a pint of oil at 5K  The post seemed to be legit and I went with it.
Roger R SVT/SHO Society SE MI rep 2000 CSVT #1253 of 2150 silver frost/midnight blue 2-8" dark blue racing stripes Mequiars...simply the best! "...and number 5, now this is the most important Rat, when it comes to making out, whenever possible, put on side one of Led Zeppelin 4" USMondeo@aol.com
Posts: 134 |
what do you get with the more oil thing???hp gains or gas milage?????
95'contour se painted interior/calipers 220wt.3-way door speakers hyfonics 100x2 amp w/audiobahn 12'subs no performance mods
Posts: 2,848 |
a motor that doesn't go boom!
I don't think the heads of the duratec hold 6 qts of oil...I think the spun bearing problem is more crank whip like terry said...however, since 6.5 qts. is safe, it's a worthwhile precaution to take.
Posts: 284 |
My Zetec holds 4.5 qts, but I put in 5 qts...If you take a hard right turn with the RPM's high it could cause oil starvation, which will/can make your engine go BOOOOOOOM! Put in a 1/2 qt more than it holds, you should be alright. I know a guy around here that puts 7 qts in his 98 SE Duratec, and the car is still running.
~*TJ*~ 97 GL Sport Zetec ~*RIP*~Connie~*1/21/02*
~*Mods*~ E0 SVT Rims~205/55R16 Goodyear American Eagles~
~*Mods to come*~ H&R springs~Konis~Coilovers~17x7 Millie Miglia Avia~215/45R17 S-03's~SVT body kit~98+ OE Spoiler~CAI~Brullen Cat-Back~Turbo (or 2):)~
More to come
