#19370 06/09/02 01:13 AM
E
eepals Offline OP
E
Is it reasonable to think Ford didn't go with a metal impeller on the Duratec water pump, was because the possibility of the drive off the cam /cylinder head breaking if the impeller got jammed in the housing? I realize the belt that drives the pump isn't under much tension, and would probably just slip, burn up or throw the belt.
I was wondering if there is an easy way to have an indicater light in the instrument cluster "LIGHT" when the temp. hits about 220 degrees?When my water pump broke, I didn't notice the temp. gauge till the needle was into the red zone. It would alert you to monitor your gauges closely.
I am sure some of the CEG engineers could tell us how it could be done. Thanks, Ed
#19371 06/09/02 05:31 AM
Just watch u'r temp gauge... i check mine bout every 6-15 secs.
"Wow, that sank fast." "Yeah, like a rock."
96 Contour GL ATX
9mm Ford Racing Wires; 2 Resonators down, 1 to go;"Special airbox"; many mods planned
Sony CD player: 50wattsx4;remote;
Speakers=50 watt Pioneer 6x8s
Ross Evans smile
