#148119 07/25/02 05:38 AM
Jazzman Offline OP
I don't mind having DRLs, but I like the look of having the fogs on during the day.
I've done the Fog w/parking lights mod, but I'd like to find a way to get the fogs on with the DRLs, instead of the parking lights.
Any ideas?
Thanks all,
Brian
1998 Mystique LS V6 ATX - Satin Green/Grey Leather
Moonroof - Ford Remote Starting System
885s for fogs - Fogs with Parks
JVC KD-SH99 MP3 - Pioneer TS-A6865s in the doors
JVC 12-Disc Changer
"Sometimes I'm good, but when I'm bad, I'm even better."
#148120 07/25/02 05:43 AM
There was a How-To on the main page when I first found this place...I have it all printed out, but no way to show anyone...it made your fogs into DRLs (on when the ignition is on RUN, on with parks, normal when headlamps are on...
YOUNGEST CEG MEMBER smile
1995 Mystique LS V6 ATX, Moonlight Blue Clearcoat Metallic, Atlantis blue cloth. Fully loaded except leather, sunroof, and CD.
1990 Pontiac 6000 S/E AWD
Brilliant White with 2-tone Gray leather, fully loaded
#148121 07/25/02 02:20 PM
Or you can just do it the easy way and wire them up to the ignition, as the drl's come on when the car is on anyways, so would the fog lights smile Just a thought.
James
jpett@flash.net
StolonTour97
Riding on 17" ADR Trauma's wrapped in Falken ZE512 215/40/ZR17
#148122 07/25/02 03:56 PM
Jazzman Offline OP
Hey all, thanks for the replies so far.
I went to the HOW TO section and didn't find the mod, so I'm either blind, or it isn't there. If anyone knows how to do this, or where the mod write-up is located, please let me know.
J Pett,
Your idea sounds great, but i'm concerned. There is a relay which controls the DRLs, they are not wired up directly to the ignition (although they would have to be indirectly hooked in). I think I would need to run a power line from the Highbeam circuit to the fogs, with a diode to keep the juice going to the fogs from going to the HBs.
It might be something similar to the Side marker mod that allows you to have the markers half-bright w/park lights, and full bright with turn signal.
Half-fogs with DRLs, and full fogs when turned on...
Maybe it would work... any ideas??
Brian
JVC 12-Disc Changer
