Page 2 of 2 1 2
You may want to try paint by SEM. They make paints for plastics and vinyls. Sand the part well with 400 wet n dry paper and use plastic prep before priming. Then apply the SEM color. Any good auto paint store should have that.
Originally posted by T-red2000se:
Well, Loco, I'll send mine to you and you can sand it down and re-do it....In exchange, I'll steal your chip.
Deal? :p
That sounds like the greatest deal anyone has ever offered me! :p
2000 Contour Zetec ATX
Hector
Mods...I got em'
"Contour grills, Contour bills, check out the oil my Contour spills."
2.SLO = 17.6 at 80mph
My profile
N
N
I would recommened using the Duplicolor high temp paint with ceramic (500 degrees). It goes on thick and smooth, and no need for clearcoat. It's the best thing I've found fo plastic thus far, and there's a pretty good color selection.
98 contour SE 2.5L MTX
resonator removed, sho shop cold air intake, arospeed muffler, painted center ring with grill insert, painted interior pieces, clear side markers, debadged and dingless.
There are special primers/sealants for plastic parts. They block the solvents in the top coat from reaching the plastic.
Also the top coat should adhere better when the primer was used.
Painting plastic is always a tricky thing. There are so many types of plastic out there and they all require different treatment.
Many plastic parts have a code somewhere on the back telling the type of plastic plastic, something like "PP", usually framed in a triangle.
You should go to an automotive paint shop and get the proper primer before you paint. They should sell it in a spray can.
On top of the primer/sealant you can probably use most common spray paints.
Might also want to ask a paint shop how much they want to paint the parts. It may not be as expensive as you think.
HTH
Joerg
I used Testors the first time, and it chipped. The second time I sanded the plastic and it has lasted over a year. If its sanded, the primer and paint will stick better.
-Ken V.
psycho_bass@hotmail.com
My Car
Page 2 of 2 1 2
