The sides in front of the doors are your front fenders.
Under the hood, as in the stuff *under* the hood or the area where the hood meets the bumper? If its the area where the hood meets the bumper, you will have your bumper cover, behind that is your crash bar. The crash bar is what gives the flexible, plastic bumper cover support in an accident. You will have your grille, its small and easy to replace (you can find them on eBay from time to time for really cheap). You also may need to replace the header panel. That is what supports the grille, air bag sensors, headlamps, and part of the corner lamps.
That pretty much covers all of the goodies. When your friend is changing everything, have them inspect the radiator support and make sure that it isn't bent. The radiator support can be seen as a body color piece that goes across the car, right where your hood latches down.
If you are looking for *new* Ford parts, look for Bill Jenkins on here. He will give you a pretty decent discount on Ford parts. I know he has posted in the past month or so in the SW-CEG forum near the bottom of the main page. For used parts, look at car-part.com. You may even be able to find the parts in the same color so everything could match.
Hope this helps.
Private Message me if you need more help.
