#147080 06/21/02 12:12 AM
right inside of those two clear plastic lenses where the other backup li8ghts were. Will post pics when done. Also can be used to ward off tailgaters:)
Black 98se V-6 sport MTX
MODS
Clear Corners, Open element,
TH fix,debaged all emblems, A6 Sidemarkers
hmmm...good way to kill somebody...Please don't use those on the road...
Ride: 2000 T-red SE
Beats: Kenwood 316S, Alpine MRF200, Orion XTR 6.2, Coustic 400SE
Mods: CTA, Magnaflow exhaust, SVT Instrument cluster, Knuaberized doors, side markers, F***ed up painted headlights.
Talk about blinding someone. We had some rear spots on our Z71 when I worked construction. they were very handy in the case of tailgaters.
Ben C
'97 Zetec Sport ATX
Pacific Green
Fog Light Re-wire
Many Mods
My Site
You think you can beat this?.....Well, you probably can
Are you leaving the plastic lenses on? Are you wiring a seperate switch for them? Can you give me any info on cost, availabilty, etc.? I wanna see pics when u'r done.
"Wow, that sank fast." "Yeah, like a rock."
96 Contour GL ATX
9mm Ford Racing Wires; 2 Resonators down, 1 to go;"Special airbox"; many mods planned
Sony CD player: 50wattsx4;remote;
Speakers=50 watt Pioneer 6x8s
Ross Evans smile
T-Redd your prob a tailgater. For the other questions It will cost approx 60$ including wiring, since the kit does not come with enough wire to run to the back. The switch is going to be rigged seperatley so they are not on blinding people all the time. As for the lense I am going to keep it on and make myself a new bracket to attache to the metal trunk lid. The fogs are the brightest in that shape that pilot puts out and you can pick them up at GI Joes. If you dont have a GI Joes you can get them most anywhere in pilot brand. A little splicing and new wire and some plastic grinding with a rotory tool and your done besides the mounting. Kit includes all fuses and most wire needed. Also the swit it include is a really good looking billet metal looking swith with a red light on the ind of it.
MODS
I need to stop trying to type so fast smile
MODS
Kinda like the Audi 'rear fog lamps'.
Dan Parmelee
1999 Acura Integra SiR-G coupe
"I heard Affleck was the bomb in Phantoms"
"Word, bitch! Phantoms like a muhfuka"
I
I
Sounds cool man post pics once done.
9
9
My mom's 00 Jag has rear fog lamps, only they are red. They are bright mothers, if you look behind you on the road when they are on, the whole entire road behind you, including raod signs, turn deep red, and when you turn them off everything goes back to black or white. Its pretty cool, I would like to do it to my svt but it would probably be too much work.
99 Tropic green svt
Custom Stereo
borla cat-back
22mm bat rear sway bar
custom K&N & heatshield
215/40/ZR17 Rubber
jimmkreider@yahoo.com
