#146787 06/12/02 05:40 AM
dwh Offline OP
Hey,
I just bought a pair of led 1157 bulbs for the mystique, and they work great. BUT, now my turn signals flash like I have a burnt out bulb. Is there a fix for this? If I put a set of amber led lights in the front, while the turn signals go back to normal? I am guessing they act this way because the led lights draw less power than normal?
95 mystique LS, High Output Cougar S (SVT) 2.5L engine & MTX75
I bought a set for my old car (pontiac grand am)and it acted the same way you are talking about. The place where I got them from told me that I had to get a varible flasher to help the led bulbs going. So maybe this is the same problem you are having too!!!!
Shaun
2000 Silver Frost Contour SVT
#322 of 2150
Born: 11/16/99
Mesh Grills
Painted Interior (silver)
Custom Decals
35% Mirror Tint
KKM Intake (with custom heat shield)
more mods coming soon!!!!!!!
You have to wire in a 6 ohm resistor.
Dan Parmelee
1999 Acura Integra SiR-G coupe
"I heard Affleck was the bomb in Phantoms"
"Word, bitch! Phantoms like a muhfuka"
Wouldnt that dim them?
Howard
1998 Silverfrost SVT #1612
June mods:
17" ADR RS Limited Limix Wheels
with 215/45/17 Yokohama AVS Sports
Administrator
Administrator
Wire the resistor in parallel. That keeps the same voltage going to the light, but adds resistance to the circuit.
ŻŻŻŻŻŻŻŻŻŻŻŻŻTŻŻŻŻŻŻŻŻŻ\
-------------Resistor-------Ŝ-Bulb
_____________|_________/
This is needed for the flasher relay. There is a metal element inside the relay that heats up and contracts. It heats up, releases the circuit (for the "off" blink), cools down quickly, then closes back. It repeats that to get the blinking.
Not enough resistance in that circuit causes the metal element inside the blinker relay to draw too many amps heating up too quickly. In order to remove some of that "excess" amperage, you need to add resistance. Depending on the amps to pull, a 6 ohm, 1/2 or higher watt resistor would be needed. The higher the wattage, the safer.
-Chris Hightower-
(Oo.Ğxxğ.oO)
o xxxxxxxxx o
dwh Offline OP
Kewl!
I'll try that resistor ASAP! Thanks! By the way, I LOVE the lights, and they only cost $12 for the pair... $16 total shipped.
E
Eli Offline
E
didnt realize 1157 was a model number, im thinking "jeez!!! what the hell is this guy gonna do with 1000 leds??" wink
96 Contour SE, MTX
2 Pioneer 12"s in a bandpass box
2 5x7 Pioneer Plates
2 Stock Speakers
600 watts of blistering radioshack power
I'm sure Hightower could think of something. laugh
"If you're pushing crazy I'm all full up here."
{Black '96 Contour SE MTX w/ over 126k on the clock}
· Get the skinny here.
· Need a 96-00 Ford Service Manual on CDROM?
Administrator
Administrator
My car will have hundreds, but not quite 1000 when I am done. wink
-Chris Hightower-
(Oo.Ğxxğ.oO)
o xxxxxxxxx o
Is that a bet? laugh
Dan Parmelee
