#145967 05/24/02 12:59 AM
Bridge Offline OP
I know there have already been a lot of posts about HID's, but I couldn't find a direct answer to my question.
1. Correct me if I'm wrong, but is 5500k bulbs a bluish color whereas 8000k is a purplish color?
2. Also is the only difference between 5000k and 8000k the color? Is the whiteness of the lights the same?
3. Is the correct size 9006?(For 98.5 SVT)
4. Can I get a kit that will convert my headlights as well as my fog lights? If so how much more for the fog lights?
5. As I live in Canada, I have day time running lights, so will they be HID as well?(Possibly a stupid question!!)
Sorry for SOOOO many questions, but all help is appreciated!! Later on!
98.5 Contour SVT - Silver Frost
Cupholders - MP3 Deck - Sub - Painted Calipers (Silver) - K&N Filter
#145968 05/24/02 01:56 AM
Administrator
Administrator
1. Yes
2. Color is "whiteness". So the color is different.
3. Yes
4. You don't want HID fogs. If you did, you'd have to get whole new assemblies.
5. Running lights are the bright lights. Not regular. Keep the regular lights for brights, and just get HID for the regular.
Keep in mind, the plug MIGHT be backwards on the ballast. Check the positive and negative before you install them.
Good luck!
-Chris Hightower-
(Oo.«xx».oO)
o xxxxxxxxx o
#145969 05/24/02 05:28 PM
jjh Offline
Originally posted by Chris Hightower:
....Keep in mind, the plug MIGHT be backwards on the ballast. Check the positive and negative before you install them.
Good luck!
I bought my HID set from autolamps-online.com and it was so easy to install. Didn't have to invert the positive and negative at all. Truly plug n play kit. Little pricey but I cannot be happier.
jjh
2000 T-Red SVT
#2134 of 2150
#145970 05/25/02 06:25 AM
Was it really plug and play installation? Sounds like something I ought to do soon!
HUNTER
2000 Contour SVT -Green
#851 of 2150
DRL Mod
35% tint
Auto-dimming mirror (temp,cmp)
